snoopy87 kolemjdoucí
Posted: Mon Oct 31, 2005 5:13 pm Post subject: Zmena Ikon cez BT pls help |
cawte ... ako sa daju zmenit ikony cez BT ... cez kabel to viem ... lenze neviem ako mam otvorit zlozku config cez VT ... a s akymi programami ... dik za pomoc. cafte |
pecanz čestný člen
14931.66 SMM
Posted: Mon Oct 31, 2005 5:14 pm Post subject: |
no přes BT to asi nepujde...
nebo se pletu?  _________________ -> SE S500i + 2GB M2 + Vodafone CZ <- |
Posted: Mon Oct 31, 2005 5:16 pm Post subject: |
to hadam NIEEEEEEEEEEEEEEEEEEEEEE .... ved sa to musi daaaaaaaat ... to musim mat cablik  |
lacibogi čestný člen
Posted: Mon Oct 31, 2005 5:28 pm Post subject: |
no ale ked pustam VNavigator tak mi pri starte vypise > Unable to connect to mobile !
Probably port settings are incorrect ... fnuk  |
Posted: Mon Oct 31, 2005 5:43 pm Post subject: |
stale p...je do portu1 vkuse ze je nepristupny alebo inu sprostost ... niesu aj na to nejake nastavenia ??? |
Posted: Mon Oct 31, 2005 5:52 pm Post subject: |
Vyskusaj v nastaveniach zaskrtnut to IRDA.  _________________ C(ME)75
Lasky |
Posted: Mon Oct 31, 2005 6:06 pm Post subject: |
neviem ako sa dostat do nastaveni k tomu Obex file system ... lebo ked kliknem pravym tak sa to oznaci do cervena |
Posted: Mon Oct 31, 2005 6:08 pm Post subject: |
Skus ALT+ENTER _________________ C(ME)75
Lasky |
Gianni83 rozumbrada
Posted: Mon Oct 31, 2005 6:17 pm Post subject: |
snoopy87 wrote: | neviem ako sa dostat do nastaveni k tomu Obex file system ... lebo ked kliknem pravym tak sa to oznaci do cervena |
a nebo Soubor --- vlastnosti  _________________ Sagem MC920 -----> Siemens M35 (s czT9) -----> M55 (fw.91 + tuna patchu) -----> CX75 (fw.25)
Gianni is BACK |
rancakdaniel kolemjdoucí
Posted: Mon Oct 31, 2005 6:23 pm Post subject: |
Ma to niekdo uz otestovane cez BT? Ja akosi nemozem stale nahodit to spojenie s OD alebo WCommandrom......  |
Posted: Mon Oct 31, 2005 6:25 pm Post subject: |
rancakdaniel wrote: | Ma to niekdo uz otestovane cez BT? Ja akosi nemozem stale nahodit to spojenie s OD alebo WCommandrom......  |
ved toto ze ani mne to nejako nejde s tym spojenim ... a COM portami .. |
Posted: Mon Oct 31, 2005 6:34 pm Post subject: |
Skusal som to tak, ze softom k BT som si vytvoril virtualne serial spojenie na COM 4-ke, a potom spustil OD....ale nic...
Este ked tak by mi mozno trocha pomohol help na ten Plugin na WCommander, lebo mi ho nechce nacital (ten help.txt ani readme.txt)
Mam Total Comander 5.51 tak dufam ze na nom to ide ....
Diki za hocijaku radu
Makavelina mecenáš
3139.36 SMM
Příspěvky na SM: 400,- |
Posted: Mon Oct 31, 2005 6:38 pm Post subject: |
U CX75 v pohodě ikony přes Bluetooth změním, v MPM...samozřejmě s patchem na otevření disků pro PC U x65 by to mělo jít stejně, předpokládám... _________________ HTC Touch Diamond -> HTC Wildfire, WildPuzzle ROM |
