:: View topic - Chyba volania do Orange
kokos111
PostPosted: Wed Mar 28, 2007 5:41 pm    Post subject: Reply with quote
hmm noo teraz to slo... Smile
iba mam nejak problem ho zapnut... ked som ho chcel dat do normal modu tak uz z papuou nekomunikuje
motorola D520 => Nokia 3310 => Sagem My X5-2 => SE T610 => a potom som konecne dostal rozum Smile - EL71 (FW45 + vela vela patchov), 512MB karta, HHS-150, DCA-110
prihlaseny
PostPosted: Wed Mar 28, 2007 5:42 pm    Post subject: Reply with quote
musis nahra New512x. mne taky skapal, nove bloky, a pre istotu aj Freia.log, a pojde wink
kokos111
PostPosted: Wed Mar 28, 2007 5:44 pm    Post subject: Reply with quote
kde to vezmem??? Crying or Very sad
prihlaseny
PostPosted: Wed Mar 28, 2007 5:48 pm    Post subject: Reply with quote
ved v papua to je d'oh! , polozka new512x
kokos111
PostPosted: Wed Mar 28, 2007 5:54 pm    Post subject: Reply with quote
heh no ale ako?
papua uz s mobilom nekomunikje...
No answer from the phone
Check port number, cable, phone, mode
prihlaseny
PostPosted: Wed Mar 28, 2007 5:56 pm    Post subject: Reply with quote
restartni pc
kokos111
PostPosted: Wed Mar 28, 2007 6:04 pm    Post subject: Reply with quote
restart nepomohol...
Sefinko
elfmaster
elfmaster
Location: Strážske (Okolie) Telefon: CSL65v53 EL71v45 + 1GB Kingston (c) Benlux
6980.53 SMM
PostPosted: Wed Mar 28, 2007 7:34 pm    Post subject: Reply with quote
Spravil si s tym nieco, ci nie???
kokos111
no po siestom pokuse to stale nejde...
uz mi ide urobit EEfull a potom EElite
potom urobim Freia.log a New512x
potialto setko v pohode, ale ked potom dam prejst z Servis modu do Normal tak pipne skape a uz sa s nim neda nic robit...
2liveman: ako si vysiel zo servis modu?
prihlaseny
PostPosted: Wed Mar 28, 2007 7:48 pm    Post subject: Reply with quote
tak ze som stlacil cervene tlacitko na mobile a sa vypol, prechod do normal modu nepouzivam nikdy
ked nejde zapnut, natlac tam svoju FF, ale uz bez upravy EEprom, stare data su prec, buffer volny
kokos111
PostPosted: Wed Mar 28, 2007 8:03 pm    Post subject: Reply with quote
nj skusal som to aj tak ze som stlacil (podrzal) cervene. vysledok rovnaky - pip a chcipnutie...
nechapem... ved ked tam natlacim tu zalohu FF co som robil, tak sa tam s nou vratia aj tie bloky z EEProm, alebo nie???
Sefinko
elfmaster
elfmaster
6980.53 SMM
PostPosted: Wed Mar 28, 2007 8:04 pm    Post subject: Reply with quote
Nevratia.
Ked sa ti to podari tak daj pls vediet ci sa odstranilo to volanie do Orange. A ako sa ti podarilo potom nahrat New512x, ked neslo spojit s PapuaUtilis???
kokos111
PostPosted: Wed Mar 28, 2007 8:06 pm    Post subject: Reply with quote
nahral som to este predtym ako som vysiel z servis modu. Az ked z neho vydem tak sa neda mobil ani zapnut ani nekomunikuje s papua...
EDIT:
Sefinko wrote:
Nevratia.
no neviem... podla mna hej... lebo stale vytaca cez reprak... Laughing
prihlaseny
PostPosted: Wed Mar 28, 2007 8:10 pm    Post subject: Reply with quote
urob to co ti pisal sefinko: mas ocistenu eeprom, a nahratim FF sa nevrati ten bordel dnuka, nahraj svoju FF zapni a uzivaj telefonu
edit: to myslis vazne? neexistuje ze vytaca, mne to nerobi uz
EDIT: mne sa to jednoducho touto operaciou pomohlo napravit, nechapem preco nejde Think
EDIT to Koko111: a to ze tvrdis ze to cele nema zmysel, ze nahratim FF sa vratia vsetky zmeny eeprom sa velmi mylis, vidim ze ten clanok si neprecital poriadne, aj ked si to tvrdil, opakujem, v eeprom ostavaju stare data po nahrati roznych FF, aj ked nahras novu FF, a si myslis ze vsetko je premazane, tak omyl velky, preto sa robi ocista EEprom, aby sa uvolnilo miesto bufferu, lebo jedneho dna sa stane, ze budes chciet prehrat FF, a nepojde, kedze v eeprom neostane ziadne miesto na zapis, citaj clanok, hned uvodne vety tam otom hovoria precitaj si to este raz
pri robeni zalohy FF sa zalohuju len aktivne data eeprom ostatok sa kukni v smelteri co je tam za hnuj Anxious
kokos111
PostPosted: Wed Mar 28, 2007 8:32 pm    Post subject: Reply with quote
clanok som cital... nechcel som tu rozsirovat nejake nepravdy...
bohuzial u mna je vysledok take ze mi to nepomohlo... Crying or Very sad a naozaj som sa snazil... Bud to nejako nefunguje alebo som neico musel spravit zle.
uz to necham tak... ked vam to este niekomu okrem livemana pojde dajte dajte vedet
Page 5 of 6
