vosimo začátečník
Založen: 29. 11. 2006 Příspěvky: 37
99.50 SMM
Zaslal: ne červenec 25, 2010 5:32 pm Předmět: How can I unlock my C62? |
I want to unlock my C62, but I can't find anything. I have an original data cable. Help me, please. |
rattle-snake všeználek
 Založen: 01. 04. 2008 Příspěvky: 613 Bydliště: Varnsdorf
15518.64 SMM
Příspěvky na SM: 460,- |
Zaslal: ne červenec 25, 2010 7:17 pm Předmět: Re: How can I unlock my C62? |
Hello vosimo!
There can appear some problems, because C62 is not pure Siemens, but OEM phone - Somebody made it for Siemens, not Siemens as such. I recommend a visit of professional service. There is an article, but it is only in czech, but it contains some picture, i hope you understand to it - http://www.siemensmania.cz/content.php?id=237 I have never unlocked these phones. I only try to help other Siemens fans I also think, that you can find a lot of tutorials on web.
BTW: Is it locked for operator or by security code? _________________ Siemens mobile stále s námi!
vosimo začátečník
99.50 SMM
Zaslal: po červenec 26, 2010 7:01 pm Předmět: Re: How can I unlock my C62? |
rattle-snake napsal: | Hello vosimo!
BTW: Is it locked for operator or by security code? |
HEllo!
Thanks for your help. I have 3 c62s, locked for operator.
Do I have to modify my cable? I'll try this method, i hope. |
15518.64 SMM
Zaslal: út červenec 27, 2010 8:20 am Předmět: Re: How can I unlock my C62? |
First you have to download Flash Programmer For Siemens v 2.83, it is best to download the latest version. Yes, you will also have to make your own C62 cable, from oroginal cable for x55 series, if you have it. You will make it by linking up 3-5, 4-7, and connecting on 2 and 9 pins source 12V (50 mA), on 9 + and on 2 -, how it is described in picture. I can try to translate something another from the article, if necessary.  _________________ Siemens mobile stále s námi!
vosimo začátečník
99.50 SMM
Zaslal: út červenec 27, 2010 4:27 pm Předmět: Re: How can I unlock my C62? |
rattle-snake napsal: | First you have to download Flash Programmer For Siemens v 2.83, it is best to download the latest version. Yes, you will also have to make your own C62 cable, from oroginal cable for x55 series, if you have it. You will make it by linking up 3-5, 4-7, and connecting on 2 and 9 pins source 12V (50 mA), on 9 + and on 2 -, how it is described in picture. I can try to translate something another from the article, if necessary.  |
Do I need a cable like this ( http://n1.vatera.hu/photos/e4/bc/18a_1_big.jpg ) with no box at the middle? |
15518.64 SMM
Zaslal: út červenec 27, 2010 8:34 pm Předmět: Re: How can I unlock my C62? |
I think, that is possible to use this cable, but I am not sure. It must be for x55 series and it also must be service cable. They made two kinds, data cable and service cable. At sight it is not possible to say, if the cable in the picture is service cable, or only data cable. It depends on marking - DCA500? 510? Sorry,I am not sure But you can try it. In the article is written only cable for x55, nothing else. You can ask somebody skilled on this forum, which cable is better to use. BTW - where are you from? _________________ Siemens mobile stále s námi!
vosimo začátečník
99.50 SMM
Zaslal: st červenec 28, 2010 6:18 pm Předmět: Re: How can I unlock my C62? |
rattle-snake napsal: | I think, that is possible to use this cable, but I am not sure. It must be for x55 series and it also must be service cable. They made two kinds, data cable and service cable. At sight it is not possible to say, if the cable in the picture is service cable, or only data cable. It depends on marking - DCA500? 510? Sorry,I am not sure But you can try it. In the article is written only cable for x55, nothing else. You can ask somebody skilled on this forum, which cable is better to use. BTW - where are you from? |
About 2 years ago i had a service cable, but I threw it away with all my Siemens accesories and mobiles. How stupid I was! Now, i have 7 Siemens mobiles. I'm from Hungary. My first Siemens was a C65!  |
15518.64 SMM
Zaslal: st červenec 28, 2010 8:35 pm Předmět: Re: How can I unlock my C62? |
It was not a good idea to throw all away I have more then 30 Siemens mobiles. It is (was) the best producer of mobile phones. I hope you will find the roght cable. But I think, it will work with any x55 cable. _________________ Siemens mobile stále s námi!
jennitha kolemjdoucí
Založen: 15. 03. 2013 Příspěvky: 1
16.08 SMM
Zaslal: pá březen 15, 2013 8:09 am Předmět: |
vosimo napsal: | I want to unlock my C62, but I can't find anything. I have an original data cable. Help me, please. |
Sorry i don't know to unlock your mobile through data cable. but i would tell one safe method to unlock your mobile that is unlock code. You can unlock your mobile through unlock code if you want to unlock code you can visit this site Mobile-unlocker.com get the code and unlock your siemens C62 .
To get the code you need to specify which country is locked now,network provider and IMEI number then they send unlock code through email. |
