Mihauek kolemjdoucí
Založen: 26. 02. 2005 Příspěvky: 4
Zaslal: so únor 26, 2005 7:12 pm Předmět: mp3 player doesn't work with x65 above v.14. |
Unfortunately I can't speak Czech, so my topic will be in English. I hope, you will help
Is any kind of trick to make this "old" Siemens mp3player ( for x35/x45 with changed plug ) work with newer firmware I've been looking for any patch or solution, but didn't find. I would like to upgrade my M65, but still have to stay in v.12 ( or 14, but there isn't big difference ), because me and mp3player are the one
It normally works with x55, x60 and x65 to v.14 (C65 also on v24).
Something now about appearing:
(When works) When I plug player, the message appears:
SIEMENS
MP3-Player USB
Ver. 4.2
After typing *#06# We can see, that Acc. field is filled by:
plugged in:
DCA-500
(When doesn't work) There is no message after pluging, but on *#06# is the same message like then when works.
Please answer in English if you would be so kind.  |
Anonymní
Zaslal: so březen 05, 2005 7:34 pm Předmět: "Upgrading" movies in CX/M65 camera |
Sorry for english. I can't speak czech
So I was thinking about upgrading resolution of movies made by CX/M 65 camera. I started thinking about this, when I saw SX1. This one has also 640x480 camera, but makes QCIF (176x144@15) movies. Normal Siemens makes sub-QCIF (128x96@12) movies. Do these cameras differ each other Is there any hardware/software possibility to make CX/M65 making movies in QCIF quality I know that on mobile screen both qualities will not differ while playing (because the screen is to small ), but on PC the difference is visible...
And one extra fast question: How to movies recording make longer than 1 minute (on v.43; ... than 30 seconds) Has anyone finally thought up  |
Mihauek kolemjdoucí
Zaslal: so březen 05, 2005 7:37 pm Předmět: |
Sorry mods for this Anonymous, but i forgot to login, and pushed bad button...
Shame on me///
If you will be so kind, delete 2 last posts |
wizaard táta fóra
Zaslal: so březen 05, 2005 7:55 pm Předmět: Re: "Upgrading" movies in CX/M65 camera |
Anonymous napsal: | Sorry for english. I can't speak czech
Well, I guess these cameras are really different but it's possible to make larger-resolution videos in my point of view. On the other hand, there's one big problem - is CX/M65 fast enough to record videos in such huge quality? That's the question...  _________________ Siemens C35i, CX65 -> SonyEricsson K700i, K750i
wizaard táta fóra
Zaslal: so březen 05, 2005 7:57 pm Předmět: Re: mp3 player doesn't work with x65 above v.14. |
Mihauek napsal: | Unfortunately I can't speak Czech, so my topic will be in English. I hope, you will help
SIEMENS
MP3-Player USB
Ver. 4.2
plugged in:
DCA-500
If I remember well, there was repaired some data cable recognisation problem, so maybe that's the reason (if the MP3 player reports that it's DCA-500). I don't know more about it.  _________________ Siemens C35i, CX65 -> SonyEricsson K700i, K750i
Anonymní
Zaslal: so březen 05, 2005 11:02 pm Předmět: |
I have the solution: connect PTT (pin7) cable with pin3. After you plug in, push PTT button for 3-5 seconds. After releasing, the phone recognizes player. If not, repeat... tested on M65 v.43
http://forum.siemens-club.ru helped.
Then I wrote first article in Poland about that on forum http://forum.siemensinfo.pl/viewtopic.php?p=79404 I know, I'm boasting  |
Mihauek kolemjdoucí
Zaslal: so březen 05, 2005 11:05 pm Předmět: |
I forgot to login again  |
