:: View topic - DCA-500
DCA-500
eTniesXcz
PostPosted: Tue Mar 01, 2005 8:44 pm    Post subject: DCA-500 Reply with quote
Jde z DCA-500 udelat sevisni kabel DCA-510.Nebo mam konektor k c65 a a druhou cast kabelu od st60 s com portem slo by to skoubit????
C00L/\ ( ! ) SIEMENS C65 ( ! ) /\ C00L
Sh@dy
PostPosted: Fri Mar 04, 2005 1:34 pm    Post subject: Re: DCA-500 Reply with quote
Ja mam DCA-500 s externym napajanim (mozes to spravit podla navodu http://www.siemensmania.cz/content.php?id=167 ja som neodletoval privod na pin 1 a teraz mi pri pripojeni mobilu aj nabija baterku...) a funguje tak isto ako DCA-510. Zatial som nemal ziadne problemy...
Meldo
PostPosted: Fri Mar 04, 2005 3:56 pm    Post subject: Reply with quote
A nezabudni si nainštalovať do kompu aj program HI-SPEED-SERIAL
a zdvojnásobí sa ti rýchlosť komunikácie z 10kb/s na 22kb/s
Sh@dy
PostPosted: Fri Mar 04, 2005 6:21 pm    Post subject: Reply with quote
Ja som si to instaloval a nic mi to nepomohlo... Ked vies preco skus prosim poradit
