:: View topic - Bezpecnosti kod E71
Bezpecnosti kod E71
Goto page 1, 2  Next
R3d:BuLL
PostPosted: Sun Oct 07, 2007 8:49 pm    Post subject: Bezpecnosti kod E71 Reply with quote
Dobry vecer chci se zeptat newite nekdo jaky je bezpecnosti kod pristroje od vyroby na BQ E71.Uz jsem zkousel 2 jeden"12345" a druhy "0000" ale zadny nepasoval a zbyva mi posledni pokus tak ho nechci bloknout.Jsem tu novacek tak newim jeste poradne jak to tu chodi
AMD Athlon64 2800+@3200+,MSI K8N NEO 250GB,512MB ram DDR400 PQI,HDD Maxtor Diamond Max 9 80GB 7.200ot,Sapphire ATi Radeon 9800pro 380/680@419/740,Siemens M55
PostPosted: Sun Oct 07, 2007 8:58 pm    Post subject: Reply with quote
Ziadny bezepecnostny kod sa nenastavuje od vyroby . AK si ho kupil z ruky tak sa opytaj majitela.
R3d:BuLL
PostPosted: Sun Oct 07, 2007 9:05 pm    Post subject: Reply with quote
No ten mi napsal ze tam zadny nenastavoval.
PostPosted: Sun Oct 07, 2007 9:07 pm    Post subject: Reply with quote
Tak na 90% klamal. Pokial ten mobil nepresiel cez 10 ruk a nenastavil ho tam niekto iny
R3d:BuLL
PostPosted: Sun Oct 07, 2007 9:13 pm    Post subject: Reply with quote
A v nekde v servisu ho nedokazi zjistit ?
PostPosted: Sun Oct 07, 2007 9:14 pm    Post subject: Reply with quote
V servise to zistia. Ale ak mas servisny kabel tak si to zistis aj sam. Smile
R3d:BuLL
PostPosted: Sun Oct 07, 2007 9:18 pm    Post subject: Reply with quote
Mohl bys mi prosimte napsat presny typ toho servisniho kabelu ,ze bych si ho koupil.
PostPosted: Sun Oct 07, 2007 9:21 pm    Post subject: Reply with quote
Najlepsie kupit DCA510 original SIEMENS a prerobit si koncovku.
R3d:BuLL
PostPosted: Sun Oct 07, 2007 9:23 pm    Post subject: Reply with quote
A nemel bys nejaky navod jak tu koncovku predelat nebo nejake schema ?
PostPosted: Sun Oct 07, 2007 9:25 pm    Post subject: Reply with quote
Ked budes mat kabel tak napis a spravime
R3d:BuLL
PostPosted: Sun Oct 07, 2007 9:26 pm    Post subject: Reply with quote
Jeste jeden dotaz kde bych ten kabel mohl koupit ?
PostPosted: Sun Oct 07, 2007 9:27 pm    Post subject: Reply with quote
Skus napisat do inzercie sem na SM
http://www.siemensmania.cz/inzerce/index.php#1457
R3d:BuLL
PostPosted: Sun Oct 07, 2007 9:28 pm    Post subject: Reply with quote
Ted jsem si vsimnul ze ten kabel je na starsi verze mobilu takze budu potrebovat nejakou koncovku na ten muj.Bude stacit koncovka z nabijecky ? Mam dve ty nabijecky jednu od toho E71 a druhou od A31.
PostPosted: Sun Oct 07, 2007 9:30 pm    Post subject: Reply with quote
Ano je ina to viem ale original kabel nieje. No koncovka s nabijacky nebude stacit. Lebo ta ma len 2 piny. A ty potrebujes aby piny boli vsetky. Cize s nejakeho lacneho HF.
R3d:BuLL
PostPosted: Sun Oct 07, 2007 9:42 pm    Post subject: Reply with quote
http://www.kabelmanie.cz/Datovy-kabel-Siemens-A55-C55-S55-SL55-M55-A60-MC60-C60-C62-CF62/ Bude stacit tenhle kabel ?
Goto page 1, 2  Next
Page 1 of 2
