:: View topic - Chyba volania do Orange
kokos111
PostPosted: Wed Mar 28, 2007 4:47 pm    Post subject: Reply with quote
urcite dam vedet...
V zalohe FF je obsiahnuta aj zaloha EEProm? lebo v tom papuovi je tolko varovani ze sa trocha bojim...
pre uistenie mam kliknut v zlozke Format FFS na EELITE a EEFULL ano?
motorola D520 => Nokia 3310 => Sagem My X5-2 => SE T610 => a potom som konecne dostal rozum Smile - EL71 (FW45 + vela vela patchov), 512MB karta, HHS-150, DCA-110
Sefinko
elfmaster
elfmaster
Location: Strážske (Okolie) Telefon: CSL65v53 EL71v45 + 1GB Kingston (c) Benlux
6980.53 SMM
PostPosted: Wed Mar 28, 2007 4:53 pm    Post subject: Reply with quote
To radsej nech napise liveman, on to skusal a ja veru netusim, ked mam pravdu povedat... Smile
kokos111
PostPosted: Wed Mar 28, 2007 4:55 pm    Post subject: Reply with quote
lebo pise to ze ci chcem formatovat EEProm...
trochu sa bojim ze ci to nezmaze aj aktivne bloky...
Sefinko
elfmaster
elfmaster
6980.53 SMM
Podla mna by nemalo... ale na 100% to povedat nemozem...
prihlaseny
PostPosted: Wed Mar 28, 2007 4:57 pm    Post subject: Reply with quote
nie, aktivne bloky to nezmaze, uvolni buffer obsadeny starymi datamy kt. boli zapisovane, mam to skusane ALE FF Si UDELEJ, vsetko sa moze stat
kokos111
PostPosted: Wed Mar 28, 2007 4:58 pm    Post subject: Reply with quote
dobre FF uz mam... takze idem nato Smile
este jedna vec co prve? EElite alebo EEfull ? alebo je to jedno?
prihlaseny
PostPosted: Wed Mar 28, 2007 5:00 pm    Post subject: Reply with quote
v tom ti poradi krokodyl, teraz si uz nepamatam co prve, ked sa nemylim EEfull znamena plny format eeprom, eeelite uvolnenie bufferu dat Think
Sefinko
elfmaster
elfmaster
6980.53 SMM
Ja si myslim, ze je to asi jdno ale daj radsej prvu EElite a potom EEfull. Aj v tom programe pre x65 trebalo najprv EElite a potom EEfull...
kokos111
PostPosted: Wed Mar 28, 2007 5:05 pm    Post subject: Reply with quote
tak som dal najskor EElite po chvili napisalo nejaky blisie nedefinovany error... a konec... nejde vobec zapnut dufam ze pojde nahrat zaloha FF
Sefinko
elfmaster
elfmaster
6980.53 SMM
PostPosted: Wed Mar 28, 2007 5:07 pm    Post subject: Reply with quote
Nechapem... livemanov-i slo v pohode... A tak som sa tesil... Crying or Very sad
kokos111
PostPosted: Wed Mar 28, 2007 5:09 pm    Post subject: Reply with quote
mozno som nieco spravil zle... ked nahram FF (chvala bohu to ide Dancing, lebo s papua uz nechcel komunikovat) tak to skusim znovu
prihlaseny
mne to slo, najprv z TP, potom ta zalozka EEfull, nezapomen, typ bcore nastavit x85
edit: takze ako to robim ja: rachlost 115000 com, type x85, a EEfull, potom eelite, bez skey to nejde
kokos111
PostPosted: Wed Mar 28, 2007 5:23 pm    Post subject: Reply with quote
TP nemam!!! Laughing
asi som nenastavil x85 Brick wall
takze najskor EEfull? kazdy hovori nico ine Laughing
EDIT: musi byt v servis mode ze? len sa uistujem...
prihlaseny
PostPosted: Wed Mar 28, 2007 5:24 pm    Post subject: Reply with quote
sprav tak ako som pisal teraz , tak som robil ja
edit: v service mode samozrejme musis byt
edit2: ako si dopadol?orange ide jak ma?
edit3:nezabudni na koniec Arrow Freia.log-New512x pre vytvorenie blokov
Sefinko
elfmaster
elfmaster
6980.53 SMM
PostPosted: Wed Mar 28, 2007 5:28 pm    Post subject: Reply with quote
jj musis byt v servisnom mode...
Page 4 of 6
