mitio kolemjdoucí
Posted: Sun Apr 17, 2005 3:26 pm Post subject: Help ME pls. Kabel MA-8730P :-prehrani FW CX65 |
poterboval bych help.. nejde mi totiz prehrat FW
aktualniFW v mobilu je FW09
kabel pracuje nechce navazat komunikaci s mobilem a kdyz nahodou jo tak to hodi hlasku:
505 No answer from Mobile,maybe not with new Update-Concent?
baterii mam nabitou uplne, nekdo radi prelepeni 2 pinu ale to stejne nepomaha, dik za jakoukoliv radu a navrh
jinak prehravani souboru normalne funguje |
Bonfire čestný člen
Příspěvky na SM: 110,- |
Posted: Sun Apr 17, 2005 3:29 pm Post subject: |
zajimave, mam stejny kabel a jede mi vsechno _________________ C1,C2,C3,C4,C5,P1,S3,S3plus,S3com,S4,S6,S8,C10,E10,S10,S10active,SL10,U10,S15,C25,C28,S25,C30,M30,A35,A36,C35,M35,S35,S40,S42,
capo di tutti capi táta fóra
vbvbvb táta fóra
Posted: Sun Apr 17, 2005 3:30 pm Post subject: |
co ti pise aky mas kabel ked das *#06# ? _________________
Posted: Sun Apr 17, 2005 3:32 pm Post subject: |
vbvbvb wrote: | co ti pise aky mas kabel ked das *#06# ? | Kabel MA-8730P _________________ Buď múdrejší ako sú ostatní, ale nepovedz im to |
mitio kolemjdoucí
Posted: Sun Apr 17, 2005 3:33 pm Post subject: |
kabel mam MA-8730P ale v mobilu mi to pise DCA-510 |
Bonfire čestný člen
Posted: Sun Apr 17, 2005 3:34 pm Post subject: |
capo di tutti capi wrote: | vbvbvb wrote: | co ti pise aky mas kabel ked das *#06# ? | Kabel MA-8730P |
to teda pochybuju melo by to byt DCA-510 - ten kabel MA-8730P mam taky _________________ C1,C2,C3,C4,C5,P1,S3,S3plus,S3com,S4,S6,S8,C10,E10,S10,S10active,SL10,U10,S15,C25,C28,S25,C30,M30,A35,A36,C35,M35,S35,S40,S42,
vbvbvb táta fóra
capo di tutti capi wrote: | vbvbvb wrote: | co ti pise aky mas kabel ked das *#06# ? | Kabel MA-8730P | Viem aky ma kabel ale chcel som vediet ako sa mu hlasi v telefone. Ale uz nic ked uz tam ma tie odkazy  _________________
Posted: Sun Apr 17, 2005 3:35 pm Post subject: |
Bonfire wrote: | capo di tutti capi wrote: | vbvbvb wrote: | co ti pise aky mas kabel ked das *#06# ? | Kabel MA-8730P |
to teda pochybuju melo by to byt DCA-510 - ten kabel MA-8730P mam taky | jasne ze sa hlasi ako DCA-510, ale ja som myslel ze aky ma kabel _________________ Buď múdrejší ako sú ostatní, ale nepovedz im to |
mitio kolemjdoucí
Posted: Sun Apr 17, 2005 3:40 pm Post subject: |
capo di tutti capi wrote: | Bonfire wrote: | capo di tutti capi wrote: | vbvbvb wrote: | co ti pise aky mas kabel ked das *#06# ? | Kabel MA-8730P |
to teda pochybuju melo by to byt DCA-510 - ten kabel MA-8730P mam taky | jasne ze sa hlasi ako DCA-510, ale ja som myslel ze aky ma kabel |
parada a vi teda nekdo co s tim? docela me to uz se*e  |
Posted: Sun Apr 17, 2005 3:41 pm Post subject: |
skus si precitat, diskusie na ktore som ti dal linky - tam sa to riesilo _________________ Buď múdrejší ako sú ostatní, ale nepovedz im to |
mitio kolemjdoucí
Posted: Sun Apr 17, 2005 3:42 pm Post subject: |
capo di tutti capi wrote: | skus si precitat, diskusie na ktore som ti dal linky - tam sa to riesilo |
ok dik snad neco pomuze, protoze uz to zkousim od rana a nic |
mitio kolemjdoucí
Posted: Sun Apr 17, 2005 3:49 pm Post subject: |
vsechny prispevky sem si procet a nenasel sem odpoved... asi budu zkousel do vecera a pak ten kabel rozmlatim o mobil  |
ficik pisatel
Posted: Sun Apr 17, 2005 4:10 pm Post subject: |
Ja mam taky 510 a musim prelepit dva levy piny a pak to de v pohode. Treba to pomuze  _________________ CX65@70
<:.Ficik.:> |
mitio kolemjdoucí
Posted: Sun Apr 17, 2005 4:15 pm Post subject: |
problem vyresen
staci vypnout mobil a pomoci Swup (zaskrtnou skip) v pohode prehrat
po startu zmacknout cerveny tlac.
dik vsem za pomoc
