:: View topic - Bookmars (zalozky) - kde presne jsou?
Grafic
PostPosted: Fri May 20, 2005 4:30 pm    Post subject: Bookmars (zalozky) - kde presne jsou? Reply with quote
Prehral jsem FW a zmizli mi, ja furt myslel, ze budou na flexce, ale ouha, chybka....takze jsou nekde ve flashi...nevite kde presne?
PostPosted: Fri May 20, 2005 4:52 pm    Post subject: Reply with quote
Zalozky by mali byt vo Flex Cache/Browser/sys/OpBookmarkDB.db
Grafic
PostPosted: Fri May 20, 2005 5:56 pm    Post subject: Reply with quote
ty jo, fakt tam jsou, respec to Hanni:)
No, ale je divny, ze po nahravani FW mi zmizli...Mam tu LG1 a mam tam linky na rusky servery, to je taky divny...asi si to tam allsiemens nejak pridava
PostPosted: Fri May 20, 2005 6:31 pm    Post subject: Reply with quote
Ano,to sa u ruskych Winswupovych FW stava,ze obcas zasiahnu aj mimo oblasti,kde by mali...aj Krokodyl mal podobny problem tusim z FW41 alebo 43.
