:: View topic - Dotaz na odstraneni operatora z pozadi "main screen&quo
This topic is locked: you cannot edit posts or make replies.     Forum Index -> Řada x65, x70
Pavel Klos
PostPosted: Wed Jun 08, 2005 3:31 pm    Post subject: Dotaz na odstraneni operatora z pozadi "main screen&quo Reply with quote
Zdravim a (mozna hloupe) prosim o radu, zda lze z main screen (S65) odstranit nazev operatora. Na odstraneni ze screensaveru existuje patch. Zde to mozna lze nejak nastavit u patche Supernet, ale nemam s tim zkusenost. Misto nazvu lze v Zobrazeni zadat i vlastni obrazek, ten se ale roztahne na urcitou plochu (idealni by bylo "transparentni nic" :-)).
Diky, Pavel
Whitek
41313.42 SMM
PostPosted: Wed Jun 08, 2005 3:37 pm    Post subject: Re: Dotaz na odstraneni operatora z pozadi "main screen Reply with quote
Diky, Pavel
Ja tam mam nastaven transparentni gif, kterej ma 1px, takze to ani nepoznas a mas tam nic... Zkus si ho vyrobit
Podpořte SiemensManii | Trička SiemensManie | twitter @VitekJezek
View user's profile Send private message Visit poster's website AIM Address MSN Messenger
This topic is locked: you cannot edit posts or make replies.     Forum Index -> Řada x65, x70 All times are GMT + 1 Hour
