:: View topic - Obrazky na pin
Obrazky na pin
Goto page 1, 2  Next
Tmik
1289.92 SMM
PostPosted: Sat Oct 22, 2005 2:33 pm    Post subject: Obrazky na pin Reply with quote
Znate nakou aplikaci na siemens cx65 na pin kde by sli dat obrazky na pin?
Drobcek9056
7860.92 SMM
PostPosted: Sat Oct 22, 2005 2:39 pm    Post subject: Reply with quote
Myslis tu animaciu,ked zadavas pin,alebo co presne?
momentalne SL55 Smile
Tmik
1289.92 SMM
PostPosted: Sat Oct 22, 2005 2:42 pm    Post subject: Reply with quote
Aplikace ktera by byla na pin a do te aplikace bych si mohl dat obrazky.
Drobcek9056
7860.92 SMM
PostPosted: Sat Oct 22, 2005 2:43 pm    Post subject: Reply with quote
To mas nejake cudne zmyslanie. Myslis tie gulocky, ktore sa ti ukazuju pri zadavani pinu? Alebo co?
Tmik
1289.92 SMM
PostPosted: Sat Oct 22, 2005 2:45 pm    Post subject: Reply with quote
Normalni java aplikaci na zamykani obrazku.
iko
PostPosted: Sat Oct 22, 2005 2:46 pm    Post subject: Reply with quote
Stale som nepochopil o co ti ide... Rolling Eyes Think
Ičo
M35i -> S65 patch-free (okrem zvuku fotaku)
+lampicka+DCA-540
"Nothing shocks me. I'm a scientist." Indiana Jones
... o zážitok viac. http://www.plusko.net/
View user's profile Send private message Yahoo Messenger
Tmik
1289.92 SMM
PostPosted: Sat Oct 22, 2005 2:48 pm    Post subject: Reply with quote
Jsou java hry a java aplikace ja potrebuji javu aplikaci aby mi zamkla obrazky.
ICEBRETON
PostPosted: Sat Oct 22, 2005 2:50 pm    Post subject: Reply with quote
asi myslel aplikaci kam by se dali vlozit obrazky a pak zabezpecit heslem.
Ericsson A1018S => Alcatel One Touch 302 =>Siemens M55+lampicka => CX65+lampicka fw25=>fw50 + DCA 510 tuning (zeleny diody, tesneni kolem joystiku)+patche
Drobcek9056
7860.92 SMM
To znamena akoze ty nechces zadavat pin,alebo len nechces aby ti ukazovalo obrazok pri zadavani pinu?
Tmik
1289.92 SMM
Ano
Drobcek9056
7860.92 SMM
PostPosted: Sat Oct 22, 2005 2:55 pm    Post subject: Reply with quote
Aha, tak to napis do fora JAVA alebo Software. Ale kto by ti s tym mohol pomoct je podla mna Sh@dy, je aj tu na fore.
Mark Pawl
PostPosted: Sun Oct 23, 2005 11:18 am    Post subject: Reply with quote
Tak si odblokuj skryté disky, ty tvoje "nejtajnější! obrázky si flákni tam, když někdo neví jak se tam dostat, tak se tam nedostane a jsi v pohodě Wink
Guest15
Location: Frýdek-Místek (malé velkoměsto kousek od Ostravy :)
PostPosted: Sun Oct 23, 2005 11:43 am    Post subject: Reply with quote
Mark Pawl to vymakal Smile
a na ty skryte disky, moc se ti tech obrazku tam nevleze, bo to nesou zas tak velke disky
Motorola T2288 -> Siemens MT50 -> Siemens CT65 -> Siemens C65 -> Siemens S65 -> Siemens SX1 konečně
PostPosted: Sun Oct 23, 2005 12:37 pm    Post subject: Reply with quote
Vyuzivam rovnaku metodu wink
Tmik
1289.92 SMM
PostPosted: Sun Oct 23, 2005 3:28 pm    Post subject: Reply with quote
To se nic nestane kdyz jsi v ve slozce system vytvorim novou slozku a tam si dam treba obrazky?
Goto page 1, 2  Next
Page 1 of 2
