:: View topic - svisle 1pix prouzky v tematech = konec s nimi :)
Goto page 1, 2, 3, 4  Next
cuir
3072.76 SMM
PostPosted: Sun Sep 18, 2005 6:51 pm    Post subject: svisle 1pix prouzky v tematech = konec s nimi :) Reply with quote
patch ovjevil jisty "ja_ma" a nasel to na SMO.a publikoval to na SF
byl sem prvni kdo to testnul a tak se nestydim to dale propagovat:)
tady je patch
Patch No.28
; *** Remove vertical lines around background image***
; Author: Vovan888
; Created: 14/09/2005
; Firmware: v.15_RUS_WinSwup_T9_firmware
replace:AE2084230C90536001A81EF053FF4146:B020
replace:AE22842300F069FE201C00F00CFF201C01F06DF9E169:B022
replace:AE23101C03608424546068460CF02DFA04AF6C46B0344F94201C:B023
replace:01240094381C18F091F80AA90A94:0024
je to na 100% funkcni ...osobne sem to otestoval
M35i->C45->M50->C55->S55->M55->SX1
http://cuir.wz.cz
madmike
PostPosted: Sun Sep 18, 2005 8:16 pm    Post subject: Re: svisle 1pix prouzky v tematech = konec s nimi :) Reply with quote
tady je patch
Patch No.28
; Author: Vovan888
Applause Applause Applause Applause Applause Applause Applause Applause Applause
SX1 + 512mb Pretec , 5 Patche's, FW15Int
Fight for Freedom... Freedom forever
[email protected] [email protected]
jaramara
PostPosted: Sun Sep 18, 2005 8:56 pm    Post subject: Reply with quote
Jaa jsem ja_ma Dancing wink
cuir
3072.76 SMM
PostPosted: Sun Sep 18, 2005 9:21 pm    Post subject: Reply with quote
jo jo ses to ty ..vedel sem ,ze ses i na SM ,ale nevedel sem jmeno ,ale ryba je stejna taklze to sesty:) kazdopadne diky za patch.Funguje paradne
http://cuir.wz.cz
jaramara
PostPosted: Sun Sep 18, 2005 9:26 pm    Post subject: Reply with quote
No uz jsem poprosil Admina o zmenu nicku, tak doufam, ze mi vyhovi Pray
Jj patch funguje! Proste Rusaci jsou borci! Applause Applause Applause Applause
SirWolf
113.96 SMM
PostPosted: Sun Sep 18, 2005 9:58 pm    Post subject: Reply with quote
K čemu je ten patch dobrej?
Moje historie mobilů: Bosch GSM COM 608 -> Alcatel OT 302 -> Nokia 3410 -> Alcatel OT 512 -> Siemens SX1 -> Nokia 2610 -> Nokia N73 -> HTC Gratia
jaramara
PostPosted: Sun Sep 18, 2005 10:04 pm    Post subject: Reply with quote
Kdyz mas nainstalovany nejaky themko, tak chybi na background imagu 1pixel zprava i zleva, coz vypada dost blbe, ja to resil trosicku jinac, ale tenhle patch je fakt dobrej!
//Themy zacinaji byt fakt ciimdal vic dokonalejsi Dancing
cuir
3072.76 SMM
PostPosted: Sun Sep 18, 2005 10:07 pm    Post subject: Reply with quote
ja to neresil:)..cekal sem presne na tenhle patch ...doposavad sem mel samy svetly tematka kde tyto dva bile prouzky nebyly videt a tak me to nestvalo ,ale ted muzu mit i tmavy:) parada...jinak asi bych to resil tak ,ze bych udelal po bocich bile prouzky i souboru eidpic.mbm a tim bych udelal stejnou sirku a bylo byale tohle je lepsi reseni.
http://cuir.wz.cz
jaramara
PostPosted: Sun Sep 18, 2005 10:10 pm    Post subject: Reply with quote
Presne takhle jsem to resil 8)
Ted uz tem BORCUM zbyva jen vymyslet jak zmenit pozadi v menu a uz to bude fakt OK! Myslim, ze je to jen otazka casu....
cuir
3072.76 SMM
PostPosted: Sun Sep 18, 2005 10:52 pm    Post subject: Reply with quote
pozadi v menu se zmenit da...neni to problem ,,jen to chce mit nainstalovanej program ,ale udela bordel v ikonach a nelibi se mi kdyz mam nainstalovanej program co bezi na pozadi ..vsechno si rad delam rucne .,,..na nic nepouzivam programy ...ani treba themerizerolf...ten sem zavrhl hned na zacatku ...jedine co pouzivam ke vsemu je adobephotoshop,mbm whizadr a t je asi tak vsechno a jeste sem tam na nejakou drobnou upravu pouziju malovani Smile jine programy nepouzivam na tvorbu grafiky ...a na patchovani pouzivam jedine Apatcher.Program na to pozadi menu jsem vyzkousel ale nelibil semi Sad ale jde to s tim asi prezit.Kazdopadne kdyz treba najdou obrazek ta by to bylo fajn ...rovnou si to predelat ve FV nebo opatchovat ....tak jak se dela vsechno ..tpo by se mi libilo..vytvorit si .mbm a prepsat k nemu cestu ..t je fajn Smile
http://cuir.wz.cz
ZeeRaX
PostPosted: Mon Sep 19, 2005 7:00 pm    Post subject: Re: svisle 1pix prouzky v tematech = konec s nimi :) Reply with quote
tady je patch
Patch No.28
; Author: Vovan888
@JA_ma heh.. taky sem si rikal, ze ty nicky jsou podobny a ten avatar Laughing ..akorat na SM ho mas nejakou divnou bar. hloubku wink
@Cuir: Ty vole.. jestli to fakt funguje, tak to je narez Applause Applause Laughing Laughing Dancing Dancing
Hnedka jak budu mit cas, tak to hazu na SXko Laughing Jak je to vyresene ? To ty pixely vypne nebo ztmavi do cerna ?
Sagem RC 825-->Sony CMD-J5-->M55 FW 91 +novej kryt(od vyroby seka)-->SX1 FW: SMO_VII-->15CZ_patched->N70MOD Laughing
cuir
3072.76 SMM
PostPosted: Mon Sep 19, 2005 7:44 pm    Post subject: Re: svisle 1pix prouzky v tematech = konec s nimi :) Reply with quote
tady je patch
Patch No.28
; Author: Vovan888
dyt pisu ,ze to funguje ..sam sem to vyzkousel ...a fakalo to...mel sem taky kapku strach ,kdyz sem byl prvni kdo to testoval ,ale vyslo to ..normalne aplikujes patch a pak kdyz tvoris backgroundimage tak ten vetsi obrazek vytvoris o velikosti 176x132 a ne 174x132 zajiste sis vsiml rozdilu ..kdyz patch neni aplikovan a pouzijes BG s rozlisenim 176x132 tak ti to nebude sedet..takze se delalo to ,ze se BG zmensilo na 174x132 a pak to sedelo ..jenze tam byly po bocich ty pixelovy pasky Sad tento patch jke odstrani a muzes dat BG o velikosti 176x132 a bude sedet jak obrazek tak i pasky budou pryc...proste luxus :)jen vsechny tematka co mas budes muset prerobit Smile..teda jen to BG budes muset predelat ..jinak je to stejne :)snad si to pochopil ....moc na to vysvetlovani nejsem
http://cuir.wz.cz
Norton
1272.54 SMM
PostPosted: Mon Sep 19, 2005 8:03 pm    Post subject: Reply with quote
Až se mi bude chtí tak to určitě taky vyzkouším.Teď by to ještě chtělo odstranit tu předělovou čáru nahoře a už si nemůžu na nic stěžovat Dancing
C35i -> MT50 -> CX65 -> SX1 -> Nokia N70
cuir
3072.76 SMM
PostPosted: Mon Sep 19, 2005 8:50 pm    Post subject: Reply with quote
myslim ,ze i barevna zmena je fajn pokrok a asi to odstranit nepujde:( kdyby to slo tak uz by se to vedelo...pac tohle bylo hodne resene tema a na to by rusaci prisli Smile ,ale nechme se prekvapit..kazdopadne jim patri velke diky DIKY Smile
http://cuir.wz.cz
paja_m55
PostPosted: Thu Sep 22, 2005 1:05 pm    Post subject: Reply with quote
vyzkouseno, fakt vyborny, rusaci sou machri!!! ted uz ty themka vypadaji zas o trochu lip,jeste by chtelo se zbavit data/nazvu profilu na hlavni obrazovce (btw nema nekdo odsud styky na rusko? Smile )
2x C35i -> OT501 -> SGH-C100 -> M55 -> SX1 -> S65 -> Nokia E50 -> Nokia E51 -> T-Mobile MDA Compact IV
--== AMD 4evr ==--
Page 1 of 4
