:: View topic - kabel
kabel
This topic is locked: you cannot edit posts or make replies.     Forum Index -> Řada x72, x75
ericos
PostPosted: Thu Dec 01, 2005 9:49 pm    Post subject: kabel Reply with quote
aky kabel potrebujem na prepojenie C75 s pocitacom? (presny typ ak to je mozne) dakujem.
Drobcek9056
7860.92 SMM
PostPosted: Thu Dec 01, 2005 9:57 pm    Post subject: Re: kabel Reply with quote
Mas na vyber DCA500, DCA510, DCA540. Napis,co chces s telefonom robit. wink
momentalne SL55 Smile
siemensM55
postrach fóra
postrach fóra
15.00 SMM
PostPosted: Fri Dec 02, 2005 9:51 am    Post subject: Reply with quote
Chces data kabel?alebo servisny?
pecanz
14931.66 SMM
PostPosted: Fri Dec 02, 2005 2:32 pm    Post subject: Reply with quote
A o každém z jednotlivých tipů máš něco napsáno zde:
http://siemensmania.cz/forum/viewtopic.php?t=10516&start=0
a nakupovat muzes napřiklad tay Smile
http://kabelmanie.cz/
tomas_m
(člen klubu SM)<br>začátečník
PostPosted: Fri Dec 02, 2005 3:56 pm    Post subject: Reply with quote
nebo na www.datovekabely.com
<< M75 >> 512mb APACER + DCA 540(original) + DCA 510(www.datovekabely.com) + FW05 -> FW12 -> FW13 <-> FW16 + Patche
ericos
PostPosted: Fri Dec 02, 2005 10:14 pm    Post subject: kabel Reply with quote
potrebujem si nastavit dialogove tlacitka cez program Direct SoftKey Editor lebo normalne to nejde v telefone.
Drobcek9056
7860.92 SMM
PostPosted: Sat Dec 03, 2005 12:41 pm    Post subject: Re: kabel Reply with quote
Tak to mas jedno,ktory si zvolis, pojde ti to dokonca aj cez IrDA, alebo BT, len si ich musis naemulovat na COM port.
PetrSku
PostPosted: Sat Dec 03, 2005 2:21 pm    Post subject: Reply with quote
Chtěl bych se zeptat jakej kabek budu potřebovat na přehrání FW a ikonek menu?
jenda^^
PostPosted: Sat Dec 03, 2005 4:12 pm    Post subject: Reply with quote
LOCK
Teď mám: Nexus S
This topic is locked: you cannot edit posts or make replies.     Forum Index -> Řada x72, x75 All times are GMT + 1 Hour
