:: View topic - Kabel k EL71.
Kabel k EL71.
deglaser
91.00 SMM
PostPosted: Fri Jun 09, 2006 8:52 am    Post subject: Kabel k EL71. Reply with quote
Kterej kabel je potreba k nahrani firmware u EL71.
PostPosted: Fri Jun 09, 2006 9:21 am    Post subject: Reply with quote
Arrow http://www.benq-siemens.com/cds/frontdoor/0,2241,sk_sk_0_130313_rArNrNrNrN_sub%253A130313_cat%253A130360_filt%253A0,00.html
Prva rada pre telefony B-S wink
deglaser
91.00 SMM
PostPosted: Fri Jun 09, 2006 11:00 am    Post subject: Reply with quote
Stanica SyncStation DSC-100
Dátový kábel USB DCA-140
Dátový kábel DCA-100
Takze tady tema kabelama to pujde? Ale proc na benqu strankach uvadej tito kabely to nechapu.
Update
Connect your mobile to the PC using one of the following cables compatible with your EL71:
Data Cable DCA-500 (serial->serial) / Data Cable USB DCA-510 (USB->serial, use only COM port 1 to 9)/ Data Cable USB DCA-540 (USB->USB).
budik01
PostPosted: Fri Jun 09, 2006 12:31 pm    Post subject: Reply with quote
jet o stejne jako predchozi kabely jenom maji tu novou uzsi koncovku a na zacatku oznaceni misto 5xx 1xx ,principialne to ale sedi:)
...........Crrrrrrrrrrrrrrrrrrrrrrrrrrr.............
mao7
PostPosted: Tue Jul 11, 2006 2:21 pm    Post subject: Rozdiel Reply with quote
Ahoj.Neviete aky je rozdiel medzi datovym a servisnym kablom k mob.telefonom.Nie je to nahodou to iste?
Miroslav Šůs
PostPosted: Tue Jul 11, 2006 5:48 pm    Post subject: Reply with quote
Pres servisni kabel muzes s mobilem temer cokoliv a pres datovej "jen" posilat obrazky, zvuky, zalohy a takovyhle veci.
C25 -> C35i -> C45 -> M55 -> MC60 -> CX65 -> SXG75(fw22) + 1GB RS-MMC + IMS 700 + HHB 700 + S75(fw40) na porovnani
