:: View topic - Zelena DIODA na EL71 + Kontakty
justyn
PostPosted: Tue Jul 18, 2006 7:29 am    Post subject: Zelena DIODA na EL71 + Kontakty Reply with quote
1. Viete mi niekto poradit ci sa da vypnut to blikanie zelenej diody ?
2. Da sa niekde v kontaktoch nastavit nieco take ako bolo na CX65 ... myslim to prepinanie medzi telefonnym zoznamom (SIM) a adresarom ? Ked som si prekopiroval kontakty zo SIM do telefonu tak mi ukazuje vsetko zdvojene. Dakujem pekne.
mao7
PostPosted: Tue Jul 18, 2006 8:42 am    Post subject: Reply with quote
no takze to zelene blikajuce svetlo sa vypnut neda no mozno neskor nejakym firmwarom novsim to pojde a tie kontakty myslim ze prepinat sa nebude dat medzi telefonym adresarom a SIMkou ako to bolo u predoslych modeloch siemens aj ja som to skusal vseliako ale neslo to bud to budes mat zdvojene alebo to kopni vsetko do phone a na kart nic skusal som to aj filtramza ani to neslo
M35 2x => S55 fw 90 => A52 => EL 71 od ORANGE
justyn
PostPosted: Tue Jul 18, 2006 9:00 am    Post subject: Reply with quote
No firmware som skusal hodit novy ale dajak ty hajzli T-mobile to nejak zablokovali ... proste sa mi nedarilo tam nahodit iny firmware.
Nemas s tym skusenosti ?
mao7
PostPosted: Tue Jul 18, 2006 10:16 am    Post subject: Reply with quote
no troska ja mam taky isty problem ja ho mam s ORANGE Crying or Very sad tu si precitaj toto hlavne http://www.siemensmania.cz/forum/viewtopic.php?t=20818&postdays=0&postorder=asc&start=360
tam je o tom nieco napisane
justyn
PostPosted: Tue Jul 18, 2006 10:21 am    Post subject: Reply with quote
Paraaada Embarassed ... takze uz len zohnat suhlas od T-mobile Razz
mao7
PostPosted: Tue Jul 18, 2006 10:37 am    Post subject: Reply with quote
nemysli si ze to bude take jednoduche Shame on you
justyn
PostPosted: Tue Jul 18, 2006 10:43 am    Post subject: Reply with quote
No to mi je uplne jasneee ... su to hajzli Brick wall
ixo555
PostPosted: Wed Jul 19, 2006 11:41 am    Post subject: Reply with quote
k tej blikajucej diodke. nebude blikat, ked si zapnes ako setric hodiny.[qu[/quote][/list][/list]
mao7
PostPosted: Wed Jul 19, 2006 12:16 pm    Post subject: Reply with quote
ale ved sak ona normalne neblika iba ak mas sms alebo neprijaty hovor alebo ti niekto poslal nejake data mne takto sama od seba neblika a estre svieti ked sa fon nabija a potom zhasne ked je nabity a ked das hodiny ako setric displeja tak aj potom ti blika ked mas neprijaty hovor sms
kimlo
PostPosted: Wed Jul 19, 2006 2:39 pm    Post subject: Reply with quote
jj, presne tak to je ako pises wink
Trium Aria -> motorola ?? -> motorola v50 -> SE T630 -> Nokia 6100 -> B-S EL71
justyn
PostPosted: Thu Jul 20, 2006 6:46 am    Post subject: Reply with quote
No neviem ale mne to stale blika ... aj ked nemam ziadny neprijaty hovor alebo SMS ci data. Inbox mam prazdny a stale to blika.
Skusim ten setric nastavit
justyn
PostPosted: Thu Jul 20, 2006 6:54 am    Post subject: Reply with quote
Ako nahle sa mi vypne display (mam nastavene "setrit energiu" ) okamzite zacne blikat dioda bezohladu na to ci mam alebo nemam nieco v inboxe.
mao7
PostPosted: Thu Jul 20, 2006 8:56 am    Post subject: Reply with quote
tak tam budes mat nejaku zradu lebo kamos co ma EL 71 tak jemu to blika ako mne iba pri neprijatych a tak a to ti v kuse blika Question
mimoklepes
PostPosted: Fri Jul 21, 2006 6:22 am    Post subject: Reply with quote
ked je ako setric nastavene setrenie energiou, tak dioda blika vzdy, ked je vypnuty displej, bez ohladu na nevybavene udalosti (neprijate hovory, sms a podobne). po zapnuti displeja by mala blikat, len ak je nejaka nova udalost.
na mojom telefone to vsak samozrejme blbne a akonahle je nejaka nova udalost, dioda zacne blikat a neprestane, ani ked si tu udalost pozriem. prestane az ked vypnem a znova zapnem telefon.
uz som mal viac zariadeni kde sa dal updatovat firmver, ale zatial si nikto nedovolil vypustit takto brutalne chybovu verziu do sveta. ked ma ludia varovali pred siemensom, ze su to hrozne chybove telefony, tak som im neveril. mal som.
mao7
PostPosted: Fri Jul 21, 2006 10:49 am    Post subject: Reply with quote
no nemozes zase nadavat na siemensy tie su uplne v poriadku ale ide o to ako tie telefony kazia operatory svojimi original firmware to nemas len ty take problemy kazdy kto ma mobil z orange a TM tak mu blbne soft keby si mal original firmware od benq siemens tak to urcite by takto neblblo to sa len mozme podakovat svojim skvelym operatorom ako nam dodrbkali telefony a aj reputaciu benq siemens a pohlad na nan
