:: View topic - S65ka+fw58+dv rs mmc
whito
4279.78 SMM
PostPosted: Mon Nov 14, 2005 6:54 pm    Post subject: S65ka+fw58+dv rs mmc Reply with quote
Nevie niekto, ako sa odlisuje
fw58 od fw50 pre S65ku?
Ja som postrehol iba, ze ked
zapinam inkognito, tak 58cka sa spita
1. (na vsetky) a 50tka
2. krat (na vsetky/nasledujuce volania).
A este nieco, chcel by som do S65ky RS MMC 512MB
Dual Voltage. 512MB RS MMC viem, ze v S65ke ide!
Ale pojde aj ta DV?
Diki very much!
Motorola Rokr E1
SE P1i
mcroslav12
PostPosted: Wed Nov 16, 2005 10:35 pm    Post subject: Re: S65ka+fw58+dv rs mmc Reply with quote
Ale pojde aj ta DV?
Diki very much!
Určite nie!!! To je ako keby si do embečky nitro!!! Shame on you Shame on you Shame on you Shame on you
Siemens C35-C35i- S55- CX65-CF75- A už mam CX75-Fw 13 original rs mmc-silicon power 256mb- dca 500 domaca vyroba
hhs 550 domaca vyroba
whito
4279.78 SMM
PostPosted: Mon Aug 28, 2006 10:32 pm    Post subject: Reply with quote
v embecke som uz nitro videl, a v S65ke 512MB RS-MMC DV Kingston Mobile slape v poho... Dancing
Motorola Rokr E1
SE P1i
sedlik15
PostPosted: Tue Aug 29, 2006 1:17 pm    Post subject: Reply with quote
neni důvod proč by to nešlo když dual voltage je podle papírů jediná podporovaná i když se říká že sou drahý tak já sem svoji Kingston Dual-Voltage 256Mb koupil za 400Kč i s dopravou přes PPL kde si za to účtovali 100Kč takže docela výhodný
M4jco
990.71 SMM
PostPosted: Tue Aug 29, 2006 5:07 pm    Post subject: Reply with quote
Ano ide to moj kamarat ma na S65 prene tu istu ale 512Mb a slape v pohode ako trojsky kon
Newer, better, simpler, shiner and much more better!
Check out my new web www.m4jco.net and write some
nice comments or help me with making that web
Wink
M4jco
990.71 SMM
PostPosted: Tue Aug 29, 2006 5:08 pm    Post subject: Reply with quote
Wink
