:: View topic - Help with SIEMENS EL71
hsngr
PostPosted: Thu Sep 07, 2006 5:01 pm    Post subject: Help with SIEMENS EL71 Reply with quote
HELLO:
I come from China.And I buy a siemens el71 mobilephone.But it's language is English,I want to change it into Chinese.But I had to crack it first. Would I use any Java tools to crack it,like the X65,X75? And where can I find it? Can you tell me? Or can you tell me the way how to carck it in order to connect with V-Klay tools
Thany you
hsngr
PostPosted: Thu Sep 07, 2006 5:21 pm    Post subject: Siemens el71 Reply with quote
My English is very poor.Not to mention your language
Plese help me
František Svoboda
PostPosted: Thu Sep 07, 2006 10:08 pm    Post subject: Reply with quote
As far as I know, there is not such possibility right now. But maybe I don't really catch up with the development... d'oh!
...tak pravím já.”
A1018s > C55 > ST60 > CF62 > MPx200 > CX65 > My-X2-2 > E71
hsngr
PostPosted: Fri Sep 08, 2006 4:55 am    Post subject: Reply with quote
Brick wall Crying or Very sad
Brick wall Brick wall
But I have seen some patches for el71
Buy the way.Can I use DCA140 to updates the version from FW22 to FW31
,use the Official FW??????????????
Update
Connect your mobile to the PC using one of the following cables compatible with your EL71:
Data Cable serial DCA-100 / Data Cable USB DCA-140 / Sync Station DSC-100
start the downloaded firmware file (.exe) and follow the instructions
