:: View topic - zablokovany kod pristroje A50
Reply to topic     Forum Index -> x62 a starší řady -> x50
x.dodo.x
PostPosted: Thu Jan 19, 2006 7:49 pm    Post subject: zablokovany kod pristroje A50 Reply with quote
Zapomnel jsem kod pristroje a zablokoval sem si ho, a jeste k tomu ten telefon mam nastaven jen pro jednu simku takze jinou tam nemuzu dat:( prosim poradte mi jak ten telefon odblokovat - nejlepe nejaky program ktery by vymazal kod pristroje nebo to proste odblokoval - mam kabel do COM1 portu.
PostPosted: Thu Jan 19, 2006 8:34 pm    Post subject: Reply with quote
Kabel musi byt servisny..program Freia-Unlocking-Direct unlock no map is saved-Use original Imei + kratko cervene tlacitko na telefone.
x.dodo.x
PostPosted: Thu Jan 19, 2006 9:38 pm    Post subject: Reply with quote
udelal jsem presne jak si mi napsal a ono mi to napise tohle:
COMM_LoadBoots : Waiting to power on the phone ...
COMM_LoadBoots : phone is powered on
COMM_SendBoot : boot file is not accepted
Co s tim?
x.dodo.x
PostPosted: Mon May 22, 2006 9:26 am    Post subject: Reply with quote
tak uz vis co by s tim mohlo byt?
PostPosted: Mon May 22, 2006 2:40 pm    Post subject: Reply with quote
Telefon sa nenabootuje.Bude treba urobit testpoint.
alkaba
10903.00 SMM
PostPosted: Mon May 22, 2006 2:45 pm    Post subject: Reply with quote
...který je docela hnusný...budeš muset rozebrat kabel, mobil a jeden pin na kabelu spojit na desce mobilu viz. Arrow http://www.siemensmania.cz/download.php?file=/testpointy/testpointA50.zip Rolling Eyes
»HTC Rose S740 with WM 6.5.3
»HP iPaq 514 with WM6.5.3
»Siemens C65
PostPosted: Mon May 22, 2006 2:47 pm    Post subject: Reply with quote
Ver mi,ze je to jeden z najjednoduchsich a nedestrukcnych testpointov
x.dodo.x
PostPosted: Mon May 22, 2006 9:17 pm    Post subject: Reply with quote
tak to myslim ze riskovat nebudu - toho ja se bojim Sad
SenorKohucik
3004.72 SMM
PostPosted: Mon May 22, 2006 10:07 pm    Post subject: Reply with quote
coho sa bojis len to tam spoj ved nemusis ani rezat Applause Applause Applause
x.dodo.x
PostPosted: Tue May 23, 2006 9:03 am    Post subject: Reply with quote
no bojim se vubec do toho telefonu lezt;) byl bych radsi kdyz aby to mi to nekdo udelal.. ja sem srab
PostPosted: Tue May 23, 2006 9:27 am    Post subject: Reply with quote
Tak navstiv servis.
Mio
10930.24 SMM
PostPosted: Tue May 23, 2006 12:19 pm    Post subject: Reply with quote
Jeste je jedna moznost, ve FREIA
v Configuration Function je vyber Boot type, u A50 musis vybrat Bootcore bug !!!
Az pokud toto nepujde udelej testpoint a odblokuj to s nastavenim Normal Boot. Abys ho nemusel delat vickrat (testpoint) rovnou vyber z Miscallenous moznost Read and Patch bootcore. A v nastaveni pak budes pracovat s Boot type na patched bootcore.
N95-8GB
x.dodo.x
PostPosted: Wed May 24, 2006 8:22 am    Post subject: Reply with quote
hanni wrote:
Tak navstiv servis.
kdybych mel penize na servis tak uz tam davno jsem;)
PostPosted: Wed May 24, 2006 8:57 am    Post subject: Reply with quote
Tak potom neviem,co Ti uz mam poradit.Skus rozne nastavenia bootcore vo Freia,ako Ti radil miosmobile,ak nepomoze a nechces sa rypat v telefone,spor koruny na servis.
Gremlin
50.96 SMM
PostPosted: Mon Sep 04, 2006 2:16 pm    Post subject: Reply with quote
Diky za radu urobil som to a slape to.
Keep smile every day
Reply to topic     Forum Index -> x62 a starší řady -> x50 All times are GMT + 1 Hour
