:: View topic - ako do x75 dat ikonky???
jupik25
PostPosted: Tue Sep 05, 2006 12:47 pm    Post subject: ako do x75 dat ikonky??? Reply with quote
daju sa do cx75 hodit ikonky do menu bez sw kabla, ale iba datoveho kabla??? a ak sa dajú tak ako.
thx
happyBOY78
PostPosted: Tue Sep 05, 2006 1:00 pm    Post subject: Re: ako do x75 dat ikonky??? Reply with quote
thx
Už mě štvou takové a podobné otázky,pořád dokola...co zkusit trochu hledat..i malý dítě umí kliknout na ikonu Hledání..
Nokia 5110,3310,3330
Siemens C35i,ME45i,S55,C55,MC60,S65,CX75 ( fw.25 ) - patched + ELF pack 2.3
Now: SE W810i
Voice: Vodafone
HHB-600,lampička,blesk,Bluetooth GPS Nokia LD-3W
Drobcek9056
7860.92 SMM
PostPosted: Tue Sep 05, 2006 2:01 pm    Post subject: Re: ako do x75 dat ikonky??? Reply with quote
thx
to je nejaky novy kabel ten sw kabel? Laughing som take este ani nepocul,neze necital, si asi myslel servisneho kabla. Nie staci ti obycajny kabel aj napr. DCA540 a das si otvorit skryte disky a potom si uz najdi presny postup niekde vo fore. Whistle
momentalne SL55 Smile
gorgeous007
PostPosted: Tue Sep 05, 2006 2:37 pm    Post subject: Reply with quote
... alebo aj IrDA, či bluetooth. Hand
alkaba
10903.00 SMM
PostPosted: Tue Sep 05, 2006 3:20 pm    Post subject: Reply with quote
bluetooth ne.. wink
»HTC Rose S740 with WM 6.5.3
»HP iPaq 514 with WM6.5.3
»Siemens C65
gorgeous007
PostPosted: Tue Sep 05, 2006 6:09 pm    Post subject: Reply with quote
alkaba wrote:
bluetooth ne.. wink
Prečo? Eh?
