:: View topic - problem
problem
Ovelord
PostPosted: Tue Dec 12, 2006 5:09 pm    Post subject: problem Reply with quote
po aplikaci nekolika pathu telefon pipne a chcipne. Nevite jakym pathem to muze byt ?? nekdy se dostanu i do menu ma CX75FW23 pls
Moucha
60.08 SMM
PostPosted: Tue Dec 12, 2006 5:11 pm    Post subject: Reply with quote
Tak zkus zrusit jeden patch po patchi a zjistis jakym to bylo wink
wmmania.cz
Podpořte SiemensManii
Koukněte co zrovna poslouchám
Ovelord
PostPosted: Tue Dec 12, 2006 5:12 pm    Post subject: Reply with quote
dela to jenom kdyz chci pres bluetooth s pc ??
pecanz
14931.66 SMM
PostPosted: Tue Dec 12, 2006 5:16 pm    Post subject: Reply with quote
hele nevíš jak můžeme vedět jaký patch to dělá když ani nevíme jaké jsi aplikoval ? Laughing Laughing
Ovelord
PostPosted: Tue Dec 12, 2006 5:23 pm    Post subject: Reply with quote
no byl to path na bluetooth ikonu
mart22
elfmaster
elfmaster
56669.28 SMM
PostPosted: Tue Dec 12, 2006 5:28 pm    Post subject: Reply with quote
tak se podivej do logu jetli to nevis: prog.files\visoft\vklay\log\telefon\telofon.log
prihlaseny
PostPosted: Tue Dec 12, 2006 7:04 pm    Post subject: Reply with quote
u rady x65 patche na ikonky irda kolabovali pri vstupe do adresara a nasledne ulozit, to iste robi pri cx75
Moucha
60.08 SMM
PostPosted: Tue Dec 12, 2006 7:05 pm    Post subject: Reply with quote
Ehm, vis o cem je rec?
wmmania.cz
