:: View topic - Online nastavenia E71
Majs0
PostPosted: Thu Mar 22, 2007 10:26 am    Post subject: Online nastavenia E71 Reply with quote
Problem: Vzdy pri vypnuti telfonu sa mi zmazu nastavenia EDGE internetu konkretne pod polozkou NAP teda APN a musim to tam zakazdym ked zapnem mobil vypisovat, nevie niekto co by stym mohlo byt?
E71 FW45 + SK langpack, 1GB Kingston , Bootkey, DCA-110, HS-150
flemo
3205.06 SMM
PostPosted: Thu Mar 22, 2007 10:58 am    Post subject: Reply with quote
Robi to aj mne, podozrievam FW45
Misisa
PostPosted: Thu Mar 22, 2007 11:28 am    Post subject: Reply with quote
Mam take fw45 a nastaveni zustava po vypnuti a zapnuti v poradku nastavene.
Edit: Nemuze tento problem co popisujete delat treba nejaka uprava?Napr.patche d'oh! d'oh! d'oh!
Motorola d460,C25,C35,S35,S45i,S55,M65,SX1,M75,SXG75, >>> E71 fw.45+512 kingston
prihlaseny
PostPosted: Thu Mar 22, 2007 11:42 am    Post subject: Reply with quote
manualne nastvanie pre t-mobile mi nejde absolutne, a zasielanie konfog.nastaveni od operatora cez sms nejde, pise Bad_Phone Sad, uz mam poprepisovane vsetko, online context, cisla, a stale nic, ani na wap, nikde sa pripojit
Misisa
PostPosted: Thu Mar 22, 2007 12:01 pm    Post subject: Reply with quote
A nepomuze polozka master reset a potom znovu nastavit??? Think
prihlaseny
PostPosted: Thu Mar 22, 2007 12:07 pm    Post subject: Reply with quote
nepomoze, budu ruske nastavenia Sad, FF mam od rusakov, ked som mal FF pomarancov, reset nahodil ich nastavenia, a FF tmobile mi nechce slapat na telefone, mrzne, zamotany kruh d'oh!
flemo
3205.06 SMM
PostPosted: Thu Mar 22, 2007 3:00 pm    Post subject: Reply with quote
je mozne, ze sa problem tyka len E71, este sa s tym budem hrat, ked bude cas.
Misisa
PostPosted: Thu Mar 22, 2007 3:22 pm    Post subject: Reply with quote
Ale ja mam take E71 a je vse v poradku.Tak kde je chyba??? Brick wall
Majs0
PostPosted: Thu Mar 22, 2007 4:15 pm    Post subject: Reply with quote
Robilo to aj pri starsom FW.
