:: View topic - thema m65
thema m65
PostPosted: Sun Apr 01, 2007 8:03 am    Post subject: thema m65 Reply with quote
ČAU potřebuji program na tvorbu themat na m65.
coyotelada22
PostPosted: Sun Apr 01, 2007 8:09 am    Post subject: Reply with quote
skus Siemens theme editor alebo na Skins skusEBS morgana vsetko stiahnes na SM
> 1 GB MS DV RS MMC Apacer
> 16 GB Micro SD class 2
>JBenchmark1 27 638 bodov
042
PostPosted: Sun Apr 01, 2007 10:05 am    Post subject: Reply with quote
a bere m65 sdt? V mobile theme editor to mám vytvářet v THEME CONCEPT V 1.0 na cx65?
coyotelada22
PostPosted: Sun Apr 01, 2007 10:09 am    Post subject: Reply with quote
preco by nemal vsak temy sa SDT subory na X 65-kach
042
PostPosted: Sun Apr 01, 2007 10:14 am    Post subject: Reply with quote
to jo ale original tam je scs a stc
coyotelada22
PostPosted: Sun Apr 01, 2007 10:17 am    Post subject: Reply with quote
ale temy SDT sa zabalene a ked ich aktivujes posto ti vzniknu scs a stc
pricom SCS je skin a STC je tama uz rozbalena a da sa kedikolvel znova
aktivovat v mobile bez rozbalovania wink
042
PostPosted: Sun Apr 01, 2007 10:19 am    Post subject: Reply with quote
takže to bude běhat
coyotelada22
PostPosted: Sun Apr 01, 2007 10:21 am    Post subject: Reply with quote
ak je spravne spravena tak ano ale inac temy sa aj na SM wink
http://www.siemensmania.cz/themes.php
042
PostPosted: Sun Apr 01, 2007 10:22 am    Post subject: Reply with quote
tak jo dík za radu
MatejP
54.46 SMM
PostPosted: Sun Apr 01, 2007 4:34 pm    Post subject: Reply with quote
A hlavně nezapoměn dát u SDTE build theme, je to nahoře v nabídce, jinak ti téma nebude fungovat. Exclamation
