:: View topic - Mrtva EL71
Mrtva EL71
sk8-ter
PostPosted: Tue Jul 24, 2007 2:18 am    Post subject: Mrtva EL71 Reply with quote
takze odisla mi elka po tom co som omylom nehal prepisat bcore lebo som si vo v_klay neviemol co mackam Brick wall Brick wall Brick wall a dal som ano povolit zapis do bootcore. neskor ked som si to uvedomil skusal som ju spojit s v_klay ale to pise ze no ziadna odpoved z boot.bin a ani papua a ani nic podobne sa mi s nim spojit nechce lebo nemoze najst boot loader. Sad telefon teraz ani nepipne ani nic . pokuste sa mi poradit hocico. cital som o testpointe ze by to asi vyriesil ale do TP sa necitim, tak som sa chcel aj spytat ze ci by mi ho dakto skusenejsi neurobil (za odmenu pochopitelne )
majsi
100.32 SMM
PostPosted: Tue Jul 24, 2007 4:55 pm    Post subject: Reply with quote
a zalohu FF mas?
sk8-ter
PostPosted: Tue Jul 24, 2007 8:05 pm    Post subject: Reply with quote
no to je jasne, mam asi tri fullflash zalohy a aj odpisane setky kody
majsi
100.32 SMM
PostPosted: Tue Jul 24, 2007 8:20 pm    Post subject: Reply with quote
a skusal si aj x65flasher? mne sa pri niecom podobnom spojil. a ak ho spustis s prepinacom -b tak sa ti bude dat obnovit aj bcore
sk8-ter
PostPosted: Wed Jul 25, 2007 12:37 pm    Post subject: Reply with quote
no skusal som ho spojit s verziou 2102. je na vyber open phone with tp
open phone with skey a pri kazdom napise no answer from loader bootkey not accepted atd
majsi
100.32 SMM
PostPosted: Wed Jul 25, 2007 7:27 pm    Post subject: Reply with quote
no ja som mal v configu x65flashera zypisane svoje kody. skus upravit config.ini takto
[Configuration]
Port=COM3
Speed=1228800
CurrentDir="cesta k nejakej zlozke(najlepsie k zlozke s FF)"
Language=0
ForceAllBlocks=1
BootMode=2
Key="BKEY","ESN"
[Bootkeys]
"nazov(je jedno co napises)"="BKEY","ESN"
a potom spust x65flasher s prepinacom -b a vyber si volbu "nazov"
BKEY , ESN a nazov bez uvodzoviek
sk8-ter
PostPosted: Thu Jul 26, 2007 8:48 pm    Post subject: Reply with quote
no skusal som to ale zasa nic uplne nic sa nezmenilo, napisalo : NO ANSWER FROM LOADER (BOOTKEY NOT ACCEPTED). CHECK WHETHER YOU VE CHOOSED RIGHT PHONE MENU. IF THIS A NEW PHONE, U NEED TO CALCULATE BOOT KEY USING BS READER MIDLET OR TESTPOINT, ja uz som z toho na dne, ale moc si vazim ze sa snazis Applause rozmyslam ze by som zbuchol ten tp ale zatial nemam ani srobovak ktorym by som elko otvoril Laughing
majsi
100.32 SMM
PostPosted: Fri Jul 27, 2007 7:42 pm    Post subject: Reply with quote
vpoho. ked ide o srubovak tak ten kupis v kazdom zeleziarstve za 30sk. a tp sa bat nemusis, neni to az take tazke
