:: View topic - A57 DEAD
A57 DEAD
39.00 SMM
PostPosted: Tue Nov 10, 2009 4:21 pm    Post subject: A57 DEAD Reply with quote
Ahoj mam tu A57 byla v kapse a pak už nešla zapnout joker mi píše tohle a freia pro jistotu spadne mám tam už udělanej TP. Prosím o pomoc díky
Start...
Loading ServiceBoot...
Sending ServiceBoot Ok.
No Ping Mobile!
Open file "D:\Download\Joker_A57w03_80-80_FF.bin" for write in Flash.
FullFlash file info:
FlashID: 002C/0017
SIEMENS A57 Sw03 lg7
RealLgPack: lg2
Start...
Loading BootsModel(A55)...
Sending StartBoot Ok.
Sending MainBoot Ok.
Com6 115200 BAUD: Ok.
Warning: HASH data error!
€ € € Sw80
Soft FlashID: 0080/0080 (0080/0080)
FlashID: 002C/0017
Flash Size: 8Mb
Region(1): Blocks 64, Size 128Kb
EEPROM segments not found!
FSN: E956ACB4 -> PhoneID: B4AC56E9
Error IMEI in OTP!
Warning: The software of the telephone does not correspond to FlashID!
HASH: 80008000800080008000800080008000
OTP IMEI is Bad! Will be used EXT IMEI: 354247001268001?
USE SKEY: 12345678
*#0000*12345678# - Network Lock
*#0001*12345678# - Service Provider Lock
*#0002*12345678# - Corporate Code
*#0003*12345678# - Phone Code
*#0004*12345678# - Network Subset Lock
*#0005*12345678# - Only Sim
WriteFlash CRC Error (0x461F3936<>0x33A853D8)! (Block at 0x800000).
14311.82 SMM
PostPosted: Tue Nov 10, 2009 6:50 pm    Post subject: Reply with quote
Skús cez Joker dať Format (keď mi nejde zapnúť C60, A65 - tak Format pomohol) Angel
39.00 SMM
PostPosted: Tue Nov 10, 2009 7:09 pm    Post subject: Reply with quote
Nedostanu se ani do service menu.
14311.82 SMM
PostPosted: Tue Nov 10, 2009 7:16 pm    Post subject: Reply with quote
To potom vyzerá na hw problém, hádam poradí mario_liptov Pray
PostPosted: Tue Nov 10, 2009 9:25 pm    Post subject: Reply with quote
Na 90% bych to viděl skutečně na HW závadu - na poškozenou flash IC, tedy výměna integrovaného obvodu, což se u tohoto modelu již nevyplatí.
14311.82 SMM
PostPosted: Tue Nov 10, 2009 9:41 pm    Post subject: Reply with quote
To je zázrak, vidieť tu znova skúseného užívateľa Krokodýl Applause
(Inak, mám doma A57 prerobený na C55 s novými orig. krytmi red Whistle ale skôr ako zberateľ, lebo ďetom sa síce aj páči, ale podľa nich nemá mp3)
bojler
300016.12 SMM
PostPosted: Wed Nov 11, 2009 12:01 am    Post subject: Reply with quote
Kdybys potreboval telefon dal pouzivat, klidne bych ti A57 predelanou na C55 prenechal. Tatinek uz ju verejne stejne pouzivat nemuze, protoze ju omylem prohlasil za odcizenou nejakou pacientkou Mr. Green
2002 C35i -> 2003 C55v24 -> 2004 S55v20 -> 2005 S65v58 -> 2006 EL71v38 -> 2007 EL71v45 + S65v58 -> 2008 EL71v45 + S65v58 -> 2009 EL71v45 -> 2010 EL71v45 patches revival -> 2013 dualSIM a konec Siemensu
14311.82 SMM
PostPosted: Sat Nov 28, 2009 5:23 pm    Post subject: Reply with quote
Kamoš mi doniesol A57 a je akoby mŕtva,
cez Joker komunikuje nestabilne Brick wall ale v niektorých situáciách sa preberie Dancing
Dal som Format, nepomohlo, poslal som ju na servis mario_liptov a dúfam, že on ju oživí Whistle
Vavricka
Phone: SX1, SXG75, SG75, S75, C75, ME75, M65, CT65, CFX65, A65, CF62, SL42, SL55, S55, M55, A55, MT50, MC60, S35, C35, M35, S25, C25, S6, S6power
686.58 SMM
PostPosted: Sat Nov 28, 2009 8:16 pm    Post subject: Reply with quote
A podle tohoto navodu by to neslo? Ja takto ozivil svoji A65 a kamaradovo A57.
maxberg
14311.82 SMM
PostPosted: Sat Nov 28, 2009 9:13 pm    Post subject: Reply with quote
Cez Joker som už uživil viacero siemensov, ale s týmto posledným A57 to akosi nejde. Podľa mario_liptov bude treba použiť teplovzdušnú pájkovačku (a tú nemám), radšej som to zveril hw expertovi Angel
PostPosted: Sat Nov 28, 2009 11:55 pm    Post subject: Reply with quote
Sorry za OT, ale ty ako redaktor by si mal vedieť, že to máš v zlej sekcii. Toto je síce rada A ale pre BQS a A57 je Siemens. Wink
// Jiri.Sko: přesunuto do správné sekce
