:: View topic - SL91 vs. SXG75 po HW stránce
Reply to topic     Forum Index -> BREW
39.00 SMM
PostPosted: Thu May 27, 2010 8:20 pm    Post subject: SL91 vs. SXG75 po HW stránce Reply with quote
Tak jsem hledal na internetu marně a proto se obracím sem. Chtěl bych zjistit rozdíly HW mezi SL91 a SXG75 (cpu, paměť ...). Jsem zvědavej jestli to co jsem zatim zjistil jsou je SW nebo HW záležitostí. Tak prosím o rady. Díky
PostPosted: Thu May 27, 2010 8:40 pm    Post subject: Reply with quote
podla allsiemens SL91 ma Qualcomm MSM6250A chipset 180 MHz (core: ARM926EJ-S) a SXG75 ma Qualcomm MSM6250 chipset 146 MHz (core: ARM926EJ-S)
viac o HW SXG75 > http://translate.google.com/translate?hl=sk&sl=auto&tl=sk&u=http%3A%2F%2Fkraze1984.narod.ru%2Fsxg75%2FHW%2Fhardrus.html
PostPosted: Fri May 28, 2010 3:39 pm    Post subject: Reply with quote
Cherooke a prezradis co si zistil?
39.00 SMM
PostPosted: Fri May 28, 2010 5:38 pm    Post subject: Reply with quote
Právě že nic a tady koukam taky nic moc Wink
Reply to topic     Forum Index -> BREW All times are GMT + 1 Hour
You cannot attach files in this forum
You cannot download files in this forum
