:: View topic - Ako to tam dostat??
Ako to tam dostat??
mahamajka
PostPosted: Fri Mar 11, 2005 9:33 pm    Post subject: Ako to tam dostat?? Reply with quote
Pray prosim poradte mi, stiahla som si na tejto stranke ikonky na baterku,signal,vibraciu,digitalen hodiny, to je super,ale za ten svet neviem ako to dostat do telefonu...mam Cx65,MPM,original kabel,dakujem Very Happy
JenaM
5904.88 SMM
PostPosted: Fri Mar 11, 2005 9:46 pm    Post subject: Reply with quote
no tak téo jsou patche takze si tu radsi precti navody na SM! je to tu vse popsane!!!
vbvbvb
PostPosted: Fri Mar 11, 2005 10:22 pm    Post subject: Reply with quote
http://www.siemensmania.cz/content.php?id=100
http://www.siemensmania.cz/content.php?id=247
PostPosted: Sat Mar 12, 2005 12:08 am    Post subject: Re: Ako to tam dostat?? Reply with quote
...a hlavne potrebujes servisny kabel...
