rioachim kolemjdoucí
Posted: Wed Mar 16, 2005 10:41 am Post subject: M55 unlock fw v91 (english only) |
I am an "outsider" from Romania so please excuse for not writing in czech.
I have recently bought a M55 v11 (I had to botcore patch it to establish a connection with V_Klay), I had some troubles with it and I took it to service. There, they have changed the firmware to v91.
My questions are:
1) Do I unlock it the same way as I unlock a v11 phone? Do Freia v9 or v10 work or I have to use ONLY Freia M55 AMD Patch?(http://www.unlockeasy.com/modules.php?name=Content&pa=showpage&pid=166 for example)
2)If I write MY v11 full backup over the installed v91 will the phone die?
3)Do you know any place I can find M55_910405_service.EXE ? (v91 with 0404 lang pack/T9)
That's all. Do write in English so I don't screw up.
Thank you. |
Posted: Wed Mar 16, 2005 12:58 pm Post subject: Re: M55 unlock fw v91 (english only) |
rioachim wrote: | My questions are:
1.Yes,this is the some way.You must use Freia 9,10 or 15.
2.No.
3.This is FW M55_910404:
http://landy.sedf.net/index.php?dir=M55_M55C/&file=M55_910404.zip
Username:mobile
Password:elibom _________________ Kdo umí, ten umí. Kdo neumí, ten čumí. |
