:: View topic - C65 a vetsi pamet?
C65 a vetsi pamet?
Guest15
Location: Frýdek-Místek (malé velkoměsto kousek od Ostravy :)
PostPosted: Sun Mar 20, 2005 2:18 pm    Post subject: C65 a vetsi pamet? Reply with quote
Uz me nebavi moc patchovat a tek sem si chtel zvetsit pamet u C65 na tech 12,71 MB mno ale cetl sem nejaky navod tu na SM a ten navazuje na BeInspired a na forru SM sem se zas docet ze ten navod na BeInspired vede k umrtveni telefonu, poradte jak na to diky.... Applause
R.I.P
3061.00 SMM
PostPosted: Sun Mar 20, 2005 2:32 pm    Post subject: Re: C65 a vetsi pamet? Reply with quote
Zvetseni pameti bych ti moc nedoporucoval... Je to HODNE NESTABILNI wink
Sony Ericsson ??? -->Blokia 3410 --> Siemens CX65 - Exclamation orig. FW 43CZ Exclamation, TENHLE foun ---všem doporučuju---
Než se zeptáte na debilní otázku, tak se podívejte sem Exclamation Exclamation Exclamation --> http://google.com
Guest15
PostPosted: Sun Mar 20, 2005 2:35 pm    Post subject: Reply with quote
Hmm tak to se na to asi vykaslu...dik
igi
PostPosted: Sun Mar 20, 2005 2:36 pm    Post subject: Re: C65 a vetsi pamet? Reply with quote
R.I.P wrote:
Zvetseni pameti bych ti moc nedoporucoval... Je to HODNE NESTABILNI wink[/quote]AZ tak velmi nestabilne to neni-mne to ficalo vpohode, az na to ze mi nesli graficke patche na urcitej adrese a to rozsirenie islo iba s fw 16 alebo 25 (neviem presne s ktorym ) Vyzera ze ta stabilita je u kazdeho phonu ina Dancing
Guest15
PostPosted: Sun Mar 20, 2005 2:40 pm    Post subject: Reply with quote
2 Igi: a kde to teda najdu to zvetseni abych si moh pohrat Smile))
R.I.P
3061.00 SMM
PostPosted: Sun Mar 20, 2005 2:42 pm    Post subject: Re: C65 a vetsi pamet? Reply with quote
2 igi: Pro ME by to za risk teda nestalo Think
igi
PostPosted: Sun Mar 20, 2005 2:48 pm    Post subject: Reply with quote
navod na svoju m65 som nasiel na beinspired.cz 8)
igi
PostPosted: Sun Mar 20, 2005 2:49 pm    Post subject: Re: C65 a vetsi pamet? Reply with quote
ja som z tych ludi co si do mobilu nahraju cokolvek... aspon sa mam s cim hrat ked sa snazim opravit umrtveny telefon
Guest15
PostPosted: Sun Mar 20, 2005 2:52 pm    Post subject: Reply with quote
to Igi: ale ja se bavim o C65ce Smile
igi
PostPosted: Sun Mar 20, 2005 3:00 pm    Post subject: Reply with quote
ja viem, prave preto som napisal ze navod na m65 som nasiel na beinspired.cz Hm, a navod na c65 tam neni?
R.I.P
3061.00 SMM
PostPosted: Sun Mar 20, 2005 3:02 pm    Post subject: Reply with quote
Ja sem ho tam nenasel...
R.I.P
3061.00 SMM
PostPosted: Sun Mar 20, 2005 3:03 pm    Post subject: Reply with quote
2 Guest15-Use google 8)
Guest15
ni neni Sad ale ja chu tych 2,7 MB navic.... Smile Applause mno a nevis kde najdu nejake jakekoliv jine obrazky pro tvorbu patchu jake kolik jine ikonky ci obrazky?nemusi byt na C65 na jaky koliv Siemens
Onecar
veterán
veterán
10894.00 SMM
PostPosted: Sun Mar 20, 2005 6:35 pm    Post subject: Reply with quote
Poradim ti: pripoj telefon k pocitaci a nekde v nastaveni najdes T9. Udelej si zalohu techto T9 a pak smaz ty ktere nepotrebujes. Kdyz smazes vsechny, zvetsi se pamet o 1MB. Neni to sice o 2MB ale kazdy MB je snad good. Jinak jsem to cetl na BI. Jestli to pofacha, tak odpovez
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger MSN Messenger
jenda^^
PostPosted: Sun Mar 20, 2005 6:37 pm    Post subject: Reply with quote
Onecar wrote:
Poradim ti: pripoj telefon k pocitaci a nekde v nastaveni najdes T9. Udelej si zalohu techto T9 a pak smaz ty ktere nepotrebujes. Kdyz smazes vsechny, zvetsi se pamet o 1MB....
Tohle je první věc co by každej měl udělat. Pak taky smazat věci jako Download assistent a photoeditor
BTW je to známý už hoooooodně dlouho......
Teď mám: Nexus S
