mymy pisatel
 Joined: 14 May 2004 Posts: 222 Location: Trenčín SLOVAKIA
Posted: Sat Mar 26, 2005 5:00 pm Post subject: Ikonky v CX65 |
Mam taky problem,chcem si zmenit ikonky v tel. ale akosi to nejde, mam aktivovany patch "superfast menu" takze koli tomu mi zrejme nefuguje Menu Creator, a ked som nasiel ikonky tak boli v formate *.png a ziadne konvertori mi ich poriadne neskonertovali na *.bmp aby to bolo pouzitelne v SPC3 nepoznate radu?  _________________ C55(fw24) -=> CX65(Fw16)->(Fw43) simply the best:) |
lacibogi čestný člen
Posted: Sat Mar 26, 2005 5:17 pm Post subject: |
Chces zmenit ikony menu? _________________ C(ME)75
Lasky |
mymy pisatel
Posted: Sat Mar 26, 2005 6:56 pm Post subject: |
Presne tak len sa mi to nedari  _________________ C55(fw24) -=> CX65(Fw16)->(Fw43) simply the best:) |
MLB všeználek
Posted: Sat Mar 26, 2005 6:59 pm Post subject: |
Nie ze ti nefunguje Menu Creator, ale SuperFast menu pouziva ikony z FF, takze preto treba pouzit SPC. Skus pouzit nieco typu Adobe Photoshop (pr. Corel Draw, PaintShop Pro, GIMP,....) a priehladnu farbu nahrad farbou 169, 171, 169 (ktosi to tu pisal na fore).... _________________ CX70 fw56 |
mymy pisatel
Posted: Sat Mar 26, 2005 7:04 pm Post subject: |
Skusim:) len skoda, ze mi gimp nesiel nainstalovat....potom dam vediet ako to slo  _________________ C55(fw24) -=> CX65(Fw16)->(Fw43) simply the best:) |
MLB všeználek
Posted: Sat Mar 26, 2005 7:09 pm Post subject: |
A mas aj kniznice GTK? (Potrebne pre GIMP) _________________ CX70 fw56 |
mymy pisatel
Posted: Sat Mar 26, 2005 7:10 pm Post subject: |
Stahoval som ich, aj tak mi to neslo, je mozne ze doslo k problemu pri ich instalacii _________________ C55(fw24) -=> CX65(Fw16)->(Fw43) simply the best:) |
mymy pisatel
Posted: Sat Mar 26, 2005 9:08 pm Post subject: |
Uz som si radsej vybral ine ikonky,kde nemam problem pri konvertovani, ale mam iny problem. Ide o ikonky zo S65 ale niesu priehladne,stale to skusam cez Malovanie, a je to uplne jedno ci mam pole "kreslit nepruhledne" zaskrknute alebo nie... _________________ C55(fw24) -=> CX65(Fw16)->(Fw43) simply the best:) |
oookoook veterán
Posted: Sat Mar 26, 2005 9:14 pm Post subject: |
mymy wrote: | Uz som si radsej vybral ine ikonky,kde nemam problem pri konvertovani, ale mam iny problem. Ide o ikonky zo S65 ale niesu priehladne,stale to skusam cez Malovanie, a je to uplne jedno ci mam pole "kreslit nepruhledne" zaskrknute alebo nie... |
A opravdu nahrazujes puvodni pruhlednou barvu tou sedou? A kdyz to mas 24b, pak musis v SPC dat nahrat obrazek 8bit, pruhlednost bude videt az v telefone. _________________ Oook Oook! |
MLB všeználek
Posted: Sat Mar 26, 2005 9:17 pm Post subject: |
Ehm, na malovanie sa radsej ****** a pouzi nieco profesionalnejsie....
Inac, bmp nemoze obsahovat priesvitne farby, proste farba 169,171,169 (seda) sa pouzije ako priesvitna..... _________________ CX70 fw56 |
oookoook veterán
Posted: Sat Mar 26, 2005 9:22 pm Post subject: |
MLB wrote: |
Inac, bmp nemoze obsahovat priesvitne farby, proste farba 169,171,169 (seda) sa pouzije ako priesvitna..... |
Co mas proti malovani? Na takovyhle veci je podle me idealni, funkce Photoshopu proste nepouzijes - staci kapatko, kyblicek, stetec a dostatecny zvetseni, abys mohl pohodlne pracovat s jednotlivejma pixelama. Vsechno v malovani mas. Proc to komplikovat? _________________ Oook Oook! |
MLB všeználek
Posted: Sat Mar 26, 2005 9:25 pm Post subject: |
oookoook wrote: | MLB wrote: |
Co mas proti malovani? Na takovyhle veci je podle me idealni, funkce Photoshopu proste nepouzijes - staci kapatko, kyblicek, stetec a dostatecny zvetseni, abys mohl pohodlne pracovat s jednotlivejma pixelama. Vsechno v malovani mas. Proc to komplikovat? |
No, pokial to uz ma konvertovane (a nechce trebars zmenit farebne urovne) tak sa da, ale skusal si uz niekedy skonvertovat nejaky obrazok v malovani (bmp->gif, png->bmp,...)? _________________ CX70 fw56 |
mymy pisatel
Posted: Sat Mar 26, 2005 9:27 pm Post subject: |
Nieco podobne sa riesi aj v casti fora pre X65...Uz som to zacal robit s tou farbou 169,171,169 len je to az moc zdlhave,ked si tu farbu vyberiem a upravim s nou ikonku, tak je vsetko OK, len ked otvorim novy obrazok, tak mi ta farba zmizne, proste neni medzi zakladnymi, a znova musim ist do polozky Upravit Barvy a vybrat tu moju...nejde niekde nieco prepisat aby ta moja farba bola medzi zakladnymi? _________________ C55(fw24) -=> CX65(Fw16)->(Fw43) simply the best:) |
