duval85 kolemjdoucí
Posted: Sat Mar 11, 2006 8:36 am Post subject: Vypnutie vibracie pri csl65essence |
Prosím pomôžte mi vyriešiť problém s vibračkom na mobile, použil som tuning patch essence všetko je ok, ale to vibrovanie sa nedá zniesť. S týmto som moc nepochodil:
>Not fully compatible with *Dynamic Provider v5* and patches that replace provider name
with some functions. You may use simultaneously screensaver in one patch and mainscreen
in the other, or viceversa
>Remove your operator logo first
>Create a folder 0:\Misc\gps
>Network change and new networks will be logged in \Misc\gps\_logfile.txt
Network files can be directly edited on phone.
You can change the default name of an network by editing the network file stored in \Misc\gps\*
>Use this String:
[action][space][text to be displayed]
action:
0 - do nothing
1-8 - switch to profile 1-8
a - Alarm
q - shutdown phone
v - vibrate two times
>Example:
"0 home" will display "home" on screen and not change the profile
"1 work" will display "work" on screen and change profile to normal environment
a s tým kódom to vyzeralo jednoduchšie- 080136C: 30 76 -to tak isto nefungovalo |
lacibogi čestný člen
Posted: Sat Mar 11, 2006 11:11 am Post subject: |
Keď nepomohlo odobrať len ten riadok (čo je zaujímavé) odober celý patch miniGPS a potom ho aplikuj so zakomentovaný príslušným riadkom.
Pridaj pred neho ; _________________ C(ME)75
Lasky |
