:: View topic - program na com
program na com
mymy
PostPosted: Fri Feb 25, 2005 9:30 pm    Post subject: program na com Reply with quote
pozna niekot program (nie drivre) pomocou ktoreho my namiesto usb portu v pc bude ukazovat com port???
C55(fw24) -=> CX65(Fw16)->(Fw43) simply the best:)
Bond
14861.00 SMM
PostPosted: Fri Feb 25, 2005 9:47 pm    Post subject: Re: program na com Reply with quote
Jestli se nepletu tak USB porty se taky řaděj mezi COM
peeero.p
PostPosted: Sun Apr 03, 2005 8:10 pm    Post subject: Reply with quote
ja mam USB na COM6 a protoze nektere programy maji ne vyber jen 4, tak bych z toho potreboval udelat COM2, 3 nebo 4. poradte pls, predem dik
sssugi
667.50 SMM
PostPosted: Sun Apr 03, 2005 8:45 pm    Post subject: Reply with quote
V ovládacích paneloch si to môžeš nastaviť wink
Vo vlastnostiach com portu--->upresniť
Siemens M65+S65+C55+DCA 510
MLB
PostPosted: Mon Apr 04, 2005 5:15 pm    Post subject: Re: program na com Reply with quote
Tak to sa pleties, USB sa neradia medzi COM - COM su seriove porty.
CX70 fw56
