:: Zobrazit téma - sw54 for cx70
sw54 for cx70
Odpovědět na téma    Obsah fóra -> Non Czech Languages Here
hotter
Založen: 04. 12. 2004
Telefon: M55
47266.46 SMM
PříspěvekZaslal: ne červenec 03, 2005 4:55 pm    Předmět: sw54 for cx70 Odpovědět s citátem
Now i have sw50 in my cx70, but i want to know what is better in sw54? May be i have to update my phone to sw54?
Onecar
veterán
veterán
Založen: 09. 03. 2005
10894.00 SMM
PříspěvekZaslal: ne červenec 03, 2005 5:31 pm    Předmět: Odpovědět s citátem
I think that there aren´t any big changes. You can stay at FW50, you may use patches, but FW54 doesn´t have any patches yet.
Zobrazit informace o autorovi Odeslat soukromou zprávu Zobrazit autorovi WWW stránky AOL Instant Messenger Yahoo Messenger MSN Messenger
szkepek
Založen: 17. 01. 2005
Bydliště: Konice - největší prdel na jih od Arktidy a na Sever od Sahary
PříspěvekZaslal: ne červenec 03, 2005 6:01 pm    Předmět: Odpovědět s citátem
Onecar napsal:
There are some patches, did you forget Smelter automatic patches Razz ?
What about FW54 ? Well, it's a little bit faster, and camera was also quite a lot improved (C65 - better colors, noise reduced...) But there aren't any bigger changes. I think, that you won't be OUT, if you stay with FW50
And what about "Smelter auto patches." I advise you patch for faster java for FW54, cause a lot of bugs were repaired..
Vita Circulus ést !!!
hotter
Telefon: M55
47266.46 SMM
PříspěvekZaslal: po červenec 04, 2005 6:17 am    Předmět: Odpovědět s citátem
i cant patch my phone because my phone sw from shop is 43 so the only way to patch is testpoint i think... testpoint is very hard to do so i think i wont do it... :cry: :cry:
So may be i will update my phonr :)
hotter
Telefon: M55
47266.46 SMM
PříspěvekZaslal: po červenec 04, 2005 7:21 am    Předmět: Odpovědět s citátem
when i updated to sw54 i had Error on waiting for Stat-Data!!! help my phone didnt turn on :cry: :cry: :cry:
hotter
Telefon: M55
47266.46 SMM
PříspěvekZaslal: po červenec 04, 2005 7:52 am    Předmět: Odpovědět s citátem
i tride to put back sw50 to phone but the same error Error on waiting for Stat-Data!!! :cry: :cry: :cry:
is so bad i dont know what to do help me plzzzzz :cry: :cry: :cry:
Little_S
Založen: 29. 05. 2004
PříspěvekZaslal: po červenec 04, 2005 10:23 am    Předmět: Odpovědět s citátem
try using official Siemens Update FW43, maybe it'll help, but i'm not sure if it helps, i've never seen an Waiting for Stat-Data error.
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
szkepek
PříspěvekZaslal: po červenec 04, 2005 6:30 pm    Předmět: Odpovědět s citátem
Well, I recommend you to use WS version of FW25, than generate kodes (which might be very useful). Then try to get there FW 54.
And what about your prob : I used to have a same one too. It's thing of configuration of your cable. You have a wrong driver, or maybe wrong COM port set in WinSwup. Check it !
Njuska
Založen: 30. 01. 2004
PříspěvekZaslal: út červenec 05, 2005 7:13 pm    Předmět: Odpovědět s citátem
I noticed: When I receive (and open) some *.txt file which hasnt "right" encoding format (for example UNICODE, UTF-8, Windows 1250...), my phone writes: "cant open"... Before, with FW50 and older my phone always "freeze".
Now, I use ANSI encoding without diacritics. I dont understand why Siemens disable multi support encoding for text files on his phones. Rolling Eyes
Zatím jsem si všimnul, že pokud přijmu a otevřu nějakej textak, kterej nema správny kodovani (napr. UNICODE, UTF-8, Windows 1250...) tak telefon napise: "Záznam nelze otevřít"... Předtím s FW50 a staršíma mi telefon vždycky zatuh.
Takže ted používam kodovani ANSI bez hacku a carek. Nechapu, proc Siemens na svejch telefonech "zakazal" podporu pro ruzne kodovani textovejch souboru.
hotter
Telefon: M55
47266.46 SMM
PříspěvekZaslal: čt červenec 07, 2005 8:41 pm    Předmět: Odpovědět s citátem
[quote="szkepek"]Well, I recommend you to use WS version of FW25, than generate kodes (which might be very useful). Then try to get there FW 54.[/quote]
I tryed to do it but my phone sw from shop is 43 so i cant to put sw25,
when i tryed to put it i had error thet phone cant update it, i tryed 3 times and i had the same error :cry:
Odpovědět na téma    Obsah fóra -> Non Czech Languages Here Časy uváděny v GMT + 1 hodina
