adigehalil začátečník
 Založen: 07. 07. 2006 Příspěvky: 34 Bydliště: sakarya/türkiye
Zaslal: st prosinec 20, 2006 7:10 pm Předmět: SXG75 theme editor |
is there any solution for the mp3 files not seen in mmc...?
nearly half of my list is missing... this phone makes me crazy...
Naposledy upravil adigehalil dne pá prosinec 29, 2006 8:06 pm, celkově upraveno 2 krát |
Zaslal: čt prosinec 21, 2006 10:12 am Předmět: |
thanks....
i have solved the problem.
i created a new folder and copy mp3s' in it... now everything is ok.
sounds folder creates the problem.....  |
martinw začátečník
 Založen: 28. 04. 2005 Příspěvky: 48
Zaslal: so prosinec 23, 2006 3:21 am Předmět: |
Actually, there may be more reasons for this not-showed files.
Somebody determined, that sxg can't handle more than +-400 files on mmc.
Next - sxg can't handle path to a file longer than 70 characters including name of file (i hope that's the correct number).
Another problem may be in id3 tags in mp3, actually with this i'm not completely sure right now - but it's worth trying to search for problem in here.
And finaly - sxg is "capable" of damaging filesystem on MMC (or even in sxg if you're unlucky). Simple format or scandisc (chkdsk) should correct this problem (on MMC).
...and there may be other problems....
2 adigehalil : yes, i know your problem is solved, i'm writing this in case somebody else encounter similar problem. _________________ C35 -> M35 -> SL45 -> SXG75 (baterka 2000 mAh home-made) |
Zaslal: čt prosinec 28, 2006 4:38 pm Předmět: |
mp3 problem is solved.
but ı have a new problem. the alarm is not working properly.
it doesn't ring...
martinw thanks for information. |
jirkab čestný člen
4280.90 SMM
Zaslal: čt prosinec 28, 2006 5:38 pm Předmět: |
Sound for alarm-clock use only those that you have store in phone (no RS MMC). 100% function! _________________ Siemens C25->S45->S55->ME45->S65->CX75->S75->SXG75->HTC Trinity->Kaiser->Blackstone->Leo->Shooter + SX1
- Jezdím Octavia Combi |
Zaslal: pá prosinec 29, 2006 8:09 pm Předmět: |
and a request again...
i am looking for theme editor...
and how can make my menu like this:
i have copied the orangehome_common.bar to the directory and restarted but nothing changed...
Naposledy upravil adigehalil dne čt leden 25, 2007 2:13 pm, celkově upraveno 1 krát |
martinw začátečník
Zaslal: čt leden 11, 2007 4:46 pm Předmět: |
martimw
thanks to pay attention... |
