steel_in_back kolemjdoucí
Založen: 03. 08. 2007 Příspěvky: 19
6.48 SMM
Zaslal: so duben 05, 2008 4:38 am Předmět: MiniGPS is a GPS or is another function? |
Hello, I install the miniGPS to my cx65@70, but i dont know what it do.
Is a improvised GPS?
How i use it? |
TUFF Stough kolemjdoucí
Založen: 13. 02. 2007 Příspěvky: 27
43.28 SMM
Zaslal: so duben 05, 2008 5:23 am Předmět: |
It only shows the strongest BTS code from your position.
By that you actually can map your location, by using other utilities, such as MapView (elf). _________________ From Indonesia with Love. Viva Siemensmania! |
delpierwin badatel
 Založen: 27. 12. 2007 Příspěvky: 146 Bydliště: Sukabumi, Republic of Indonesia
519.20 SMM
Zaslal: ne duben 06, 2008 8:06 am Předmět: |
As my friend Tuff said, it's only display LAC (Local Area Code) and CI (Cell ID) of the strongest cell, You can put them anywhere on mainscreen, or edit it's name (by TMO Editor), i mean change those numbers to any name You like, example show where are Your position now. _________________ SiemensXP | My Blog
BenQ Siemens EL71 v45 Diamond Style
Siemens ME45 Standard
Siemens A70 Almost die -- dying
Siemens S57 v17 Standard
Siemens SX1 v15 Cristal 2+
Siemens M65 Windows 7 v1.1
Siemens S75 v47 Katie Meula Case
HTC Touch Pro - Timolol's WM6.5 Stock Like ROM |
D4X (o(^^)o)
Zaslal: ne duben 06, 2008 10:54 am Předmět: |
Yes and if you edit tmo and write in number of profile you want, when phone find tmo's BTS, the profile switches automatically. I used it, when i went to school no manually switching. When I went to school the profile changed to second pr. and when I came back home, it switched to first profile. It's necessary to play with it  _________________ -> Nokia Lumia 800 |
6.48 SMM
Zaslal: út duben 08, 2008 6:39 pm Předmět: good! |
Wow! It´s amazing
Now I have 12 places in my cx65
Thanks for the help, you are the best!!!! |
D4X (o(^^)o)
Zaslal: út duben 08, 2008 7:12 pm Předmět: |
only 12? We, Czechs and Slovaks has more than 15.000 : D it's whole country  _________________ -> Nokia Lumia 800 |
6.48 SMM
Zaslal: so duben 12, 2008 7:23 am Předmět: |
I need some time to play with this function. Is very interesting, now I have 20 places, it`s very difficult in my country, because there are more than 7 code detections for place.
Well, my cx70 only needs a memorystick module to become a superchumba.  |
D4X (o(^^)o)
Zaslal: so duben 12, 2008 10:02 am Předmět: |
Take a look on patches.kibab.com, I think, there was thousands of tmo files for tens of providers (if you're from Russia) _________________ -> Nokia Lumia 800 |
Gwin čestný člen
0.84 SMM
Zaslal: so duben 12, 2008 5:11 pm Předmět: |
Podle IP to vypadá na Mexiko. _________________ Alcatel 301 => Alcatel 301 => Nokia 3210 => Nokia 3310 => Nokia 3410 => Siemens SX1 => Nokia E51-1 => HTC TyTN II => Samsung GT-I8190
