Orpheus čestný člen
14900.34 SMM
Zaslal: ne leden 16, 2005 9:56 am Předmět: |
nasiel som super navod. Myslim ze by to mal neaky moderator dat ako navod.
Hi guys,
i had the same problem with my CX70 due to finger troubles at the EEPROM tool and pressing save all.
I wasn't able to write back the blocks 5008, 5009, 5077, 5121, 5123 with the EEPROM tool - error 15.... And i didnt have a patched bootcore...
After searching and searching in all my known forums I found a solution.
You need following programs and files:
1. X65flasher-1054: this version is able to connect without the bootcore patched
you can get it here: http://www.forum.siemensmania.cz/utility.php?page=3&type=2
even i dont speek czech i was able to register there :-)
2. EEPROM tool
3. a backup of the EEPROM - best would be yours, but also another one from the same model should do (it could be that block 5009 makes troubles)
4. smelter: http://avkiev.siemens-club.ru/Siemens/Smelter/Smelter.rar
1. start x65flasher min. version 1054
2. connect to the dead phone
3. press "read flash", takes a few minutes!
4. at the place where you saved the file in step 3., create a directory called EEPROM (needed for smelter and so on)
5. start EEPROM tool
6. load the "backup" EEPROM files into the the tool (right side load)
7. save the EEPROM blocks you need (e.g. 5008, 5009...) as file type *.bin in the EEPROM directory you created, choose the same name you choose at x65 flasher and add an underscore _ followed by the block number! e.g. cx70_5008.
EEPROM tool saves the blocks now into 2 files: *.bid (a description for smelter) and *.bin (the block itself)
8. repeat step 7 for all EEPROM blocks you need
9. start smelter
10. open the backup you created with 3.
11. press "E" in the menu bar (EEPROM blocks)
12. choose the EEPROM block number you have to replace and click right with mouse, choose "load block from the file" - here it is important that you saved the EEPROM blocks in the directory "EEPROM" and with the correct name otherwise smelter won't find the file (in the error message you see how the file should look like)
13. repeat step 12 for every block you need to be replaced
14. now save the whole file with "save as"
15. start the x65flasher and connect to the phone
16. click write flash - takes again a few minutes
your phone should work again (mine is working again) |
jiji2004 všeználek
 Založen: 22. 09. 2004 Příspěvky: 743
Zaslal: ne leden 16, 2005 1:38 pm Předmět: |
Orpheus napsal: | nasiel som super navod. Myslim ze by to mal neaky moderator dat ako navod.
Hi guys,
i had the same problem with my CX70 due to finger troubles at the EEPROM tool and pressing save all ....
Símtě, mohl bys uvést zdroj ze kterýho jsi tenhle příspěvek vytáhnul? Dík moc  |
Orpheus čestný člen
14900.34 SMM
milan_ruzicka všeználek
 Založen: 30. 08. 2004 Příspěvky: 734 Bydliště: Překrásné Brno
Zaslal: ne leden 16, 2005 3:23 pm Předmět: |
Ještě musíš změnit IMEI,ale nevím jak...kdybys celej den v kuse hledal určitě bys něco našel,ale já fakt nevím _________________ Chybama se člověk učí, škoda, že Siemens není člověk...škoda, že Siemens už není mezi námi...
CX65v50 |
Orpheus čestný člen
14900.34 SMM
Zaslal: ne leden 16, 2005 4:53 pm Předmět: |
No, uz som ten mobil ozivil. Cez x65flasher 1054 som vygeneroval bios password ktory sa dal do *.vkp a dal som ho do v_klayu ako boot. Tak som spojazdnil v_klay s mobilom a dal som patch na ODforever a odokrytie 6blokov eeprom. Potom som sa pripojil cez Siemens eeprom tool a zalohoval som celu eeprom pamet. A na nete som nasiel uzasny program. Clickol som tam "repair" a bolo. Opravil. Vygeneroval si Hash key, IMEI,... Je to velmi zaujimavy prog. a siemensmania ho zatial k stiahnutiu nema. Ma odblokovanie telefonu jednym tlacitkom, zablokovanie, repair a restore. Tu je: http://www.orpheus.sizzly.com/x65.rar A neaky moderator by ho mohol dat do zoznamu programov na SM. |
Krokodýl čestný člen
Zaslal: po leden 17, 2005 8:04 am Předmět: |
Orpheus napsal: | No, uz som ten mobil ozivil. Cez x65flasher 1054 som vygeneroval bios password ktory sa dal do *.vkp a dal som ho do v_klayu ako boot. Tak som spojazdnil v_klay s mobilom a dal som patch na ODforever a odokrytie 6blokov eeprom. Potom som sa pripojil cez Siemens eeprom tool a zalohoval som celu eeprom pamet. A na nete som nasiel uzasny program. Clickol som tam "repair" a bolo. Opravil. Vygeneroval si Hash key, IMEI,... Je to velmi zaujimavy prog. a siemensmania ho zatial k stiahnutiu nema. Ma odblokovanie telefonu jednym tlacitkom, zablokovanie, repair a restore. Tu je: http://www.orpheus.sizzly.com/x65.rar A neaky moderator by ho mohol dat do zoznamu programov na SM. |
No a co třeba číst i návody na hlaní stránce http://www.siemensmania.cz/content.php?id=288 , víš co by sis ušetřil práce? Ale je fajn že jsi na hodně věcí přišel. _________________ Zálohovat, zálohovat, zálohovat!!!
Orpheus čestný člen
14900.34 SMM
Zaslal: po leden 17, 2005 4:10 pm Předmět: |
No, hej, aspon mam nove skusenosti. Ale ten prog co som dal je cool. |
Zaslal: út leden 18, 2005 8:22 am Předmět: |
Orpheus napsal: | No, hej, aspon mam nove skusenosti. Ale ten prog co som dal je cool. |
Ano je, ale nepracuje korektně se všemi Windows. Program je z listopadu a tehdy jsem ho zkoušel. Na laptopu s WIN XP-home mi krásně zrestartuje systém, doma na PC XP-home v pohodě. Nechápu proč, ale zkoušel jsem to na několika PC a někde jde a někde restartuje systém. _________________ Zálohovat, zálohovat, zálohovat!!!
Zaslal: út leden 18, 2005 9:26 am Předmět: |
To mozno je,ale ako pisal Krokodyl,nefunguje na vsetkych WIN a ani so vsetkymi FW. Takze si skor svetla vynimka.Ale ten program tusim v Utilitach mame.Mam dojem,ze som ho tam daval. _________________ Kdo umí, ten umí. Kdo neumí, ten čumí. |
Orpheus čestný člen
14900.34 SMM
Zaslal: út leden 18, 2005 2:39 pm Předmět: |
No, ale ked ma niekto v tahu mobil ako som mal ja, tak sa mu moze zist. |
Zaslal: út leden 18, 2005 2:54 pm Předmět: |
Ked je mobil v tahu,treba skusit vsetko.  _________________ Kdo umí, ten umí. Kdo neumí, ten čumí. |
Orpheus čestný člen
14900.34 SMM
Zaslal: út leden 18, 2005 3:22 pm Předmět: |
To hej, uz mam skusenost  |
