:: View topic - WS- No answer from Mobile,maybe not with new Update-Concept?
Goto page Previous  1, 2, 3, 4  Next
PostPosted: Wed Jan 26, 2005 3:47 pm    Post subject: Reply with quote
Ja nechapem co Ty stvaras clovece..Ty si chaosak jak svina
Brick wall
Dieg0
19990.28 SMM
PostPosted: Wed Jan 26, 2005 3:51 pm    Post subject: Reply with quote
Brick wall
Poprosil by som nejaku radu radsej Smile
PostPosted: Wed Jan 26, 2005 3:53 pm    Post subject: Reply with quote
A co Ti mam viac poradit...uz Tu mas vsetko,co potrebujes vediet...chyba je uz iba medzi pocitacom a telefonom wink
Ak mas DCA510,skus zapnut dobijanie,aby mal telefon stavu.
Dieg0
19990.28 SMM
PostPosted: Wed Jan 26, 2005 4:00 pm    Post subject: Reply with quote
Ked mam vypnute napajanie tak mi WinSwup telefon vypne a napise chybu volaco No answer ale ked zapnute tak nic a hodi tu chybu
Dieg0
19990.28 SMM
PostPosted: Wed Jan 26, 2005 4:01 pm    Post subject: Reply with quote
FW som si stihaol zo SM.Neni problem v tom ze to neni subor XBI?
BEZY
81.16 SMM
PostPosted: Wed Jan 26, 2005 4:15 pm    Post subject: Reply with quote
http://www.siemensmania.cz/forum/viewtopic.php?t=6799
http://www.bezysoftware.net
Brew Mobile Commander 2.0
vcelak
PostPosted: Wed Jan 26, 2005 4:18 pm    Post subject: Reply with quote
A blbá otázka, nezapomínáš mačkat takové to kouzelné červené tlačítko na mobilu?
S25 v44, C35i v18 tuned, S35 v25, ME45i v 04 tuned, S55 v91 tuned and QTEK8310
Dieg0
19990.28 SMM
PostPosted: Wed Jan 26, 2005 4:22 pm    Post subject: Reply with quote
jo jo nezapominam
vcelak
PostPosted: Wed Jan 26, 2005 4:26 pm    Post subject: Reply with quote
Dieg0 wrote:
jo jo nezapominam
Dalsi vec, mas upraveny kabel na servisni? (ty dva rezistroy navic...)
Zkus snizit rychlost komunikace, lae na 115200 by to melo VZDYCKY chodit, nikdy jsem rychlost nemusel snizit.
Dieg0
19990.28 SMM
PostPosted: Wed Jan 26, 2005 4:28 pm    Post subject: Reply with quote
Ja mam servisny doma s napajanim MA-8720-C
Dieg0
19990.28 SMM
PostPosted: Wed Jan 26, 2005 4:36 pm    Post subject: Reply with quote
BEZY wrote:
Mohl bych na to napsat knihu Rolling Eyes
Spustíš, nastavíš rychlost na 115200, vybereš COM port. Teď máš 2 možnosti:
1) Zapnutý mobil připojíš na kabel, obě zatržítka necháš prázdná
2) Vypnutý mobil připojíš na kabel, zatrhneš obě zatržítka
Zmáčkneš start
Pokud si použil 1. možnost, tak po vypnutí mobilu (Winswup si ho sám vypne) zmáčkni červené tlačítko.
Pokud si použil 2. možnost, tak nevim-to sem nikdy nezkoušel. Ale pokud to nebude nic dlouho dělat, tak ho zmáčkni
Telefon necháš až do konce v klidu, po nahrátí se sám zapne a ty už si můžeš užívat nového FW wink
2, sposob mi nejde vyhodi mi error : Error on waiting for Ack EOT
hamsa
(člen klubu SM)<br>rozumbrada
PostPosted: Wed Jan 26, 2005 4:38 pm    Post subject: Reply with quote
Uz jsem tu precetl spustu navodu a rad jak ten winswup zprovoznit ale porad marne.
Kdyz jsem updatoval s winswupem na fw 16 slo to uplne snadno,ale na ten fw 41 se stim nemuzu domluvit.
Kdyz necham telefon zapnuty a nezaskrtavam ani jeden skip tak mi to napise "Could not ping mobile"
Kdyz se snazim dostat do nastaveni com portu sekne se mi vzdycky cely pocitac.
Zkusil jsem to nastavit v registrech,ale take bez efektu.
Kdyz telefon vypnu a zaskrtnu oba dva skipy,tak se nedeje vubec nic.
Vypada to ze se asi budu muset spokojit s fw 25.
C35 -> S45 -> S45i -> S55 ->S65
Dieg0
19990.28 SMM
PostPosted: Wed Jan 26, 2005 4:48 pm    Post subject: Reply with quote
Mne pri skipech ukaze: Error on waiting for Ack EOT
Haldy
698.10 SMM
PostPosted: Wed Jan 26, 2005 4:54 pm    Post subject: Reply with quote
Ja jsem updatoval s fw25 na winswupovy fw41 a v pohode Smile. Postupoval jsem takto:
1) Vypnul jsem telefon a vytahnul SIM kartu
2) Zapnul jsem winswup a nastavil rychlost 115200 kb/s a COM1
3) Oba checky jsem nechal zaple a pripojil jsem zapnuty tel. (bez SIM katy) na kabel
4) Zmacknul jsem Start a winswup si telefon nasel, vypnul ho a zacal updatovat. Upozornuju, ze jsem nemusel mackat cerv. tlacitko, ale update zacal sam hned po vypnuti.
Mozna je to taky tim, ze mam doma delany seriovy (ne USB) servisni kabel
Mobilní historie:
Dancall => C35i@M35i => ME45@S45i => A55,A57@C55 => C65 => M75 (všechny Patchované) => E-Ten Glofish X500 (WM6 lite)
Dieg0
19990.28 SMM
PostPosted: Wed Jan 26, 2005 4:55 pm    Post subject: Reply with quote
Zkusim.Jinak diki.Povim jak dopadlo
Page 2 of 4
