:: View topic - Zmena názvu telefónu u Siemensov x65
Goto page Previous  1, 2
Dieg0
19990.28 SMM
PostPosted: Wed Feb 16, 2005 9:50 am    Post subject: Reply with quote
Tak to bylo i v navodu ne?Dieg0
xxx65xxx
Guest
PostPosted: Wed Feb 16, 2005 10:04 am    Post subject: Som asi cvok Reply with quote
hamsa wrote:
Nejednodussi to budes mit kdyz si nastavis offset na 00090180 a opises tamcely radek ktery je u neho.Vsech 32 znaku a pak si je uz prepises jak chces.Ve V/Klay by to melo vypadat takhle.
PUVODNI DATA NOVE DATA
90180: xxxxxxxx yyyyyyyyy
Ale ja chcem zmenit nazov siemens a ak sa nemylim tak ten jae na adrese 00090170. A vo V_KLAY mam zapisane len toto 00090170: 30 32 30 30 00 32 35 00 53 45 58 59 00 00 00 00 som tak blby alebo to je take zlozite. Brick wall
PostPosted: Wed Feb 16, 2005 10:06 am    Post subject: Re: Som asi cvok Reply with quote
Si asi taky blby. xe. Ale ani ja to newjwm tak si stoho nic nerob. xe
Dieg0
19990.28 SMM
PostPosted: Wed Feb 16, 2005 10:10 am    Post subject: Reply with quote
Robim s kamaratom program ktory bude univerzalny pojdu na nom vsetky X65 okrem A65 a aj FWcka tam budu skorovsetky.No nehajme sa perkvapit.Uvidime ci vobec pojde.Dieg0
romulus
VIP
VIP
PostPosted: Wed Feb 16, 2005 10:20 am    Post subject: Re: Som asi cvok Reply with quote
Mezi jednotlivými hex hodnotami se nepíšou mezery!! Mezera odděluje stará a nová data....
Dieg0
19990.28 SMM
PostPosted: Wed Feb 16, 2005 10:23 am    Post subject: Re: Som asi cvok Reply with quote
Moje rec.Jinak romulus problemy s navodem budemem resit az bude ten program a kdyz nepojede OK?Diegé
xxx65xxx
Guest
PostPosted: Wed Feb 16, 2005 10:29 am    Post subject: Re: Som asi cvok Reply with quote
Takze predsa som iny. xi A tak ako ma vypadat ten moj napis? Ma tam byt napisane SEXY S65 . Ak som to dobre pochopil tak vo V_KLAY maju byt zapisane 2 riadky jeden stare data a jeden to co chcem? Volajte ma cvoky. xi Brick wall
Dieg0
19990.28 SMM
PostPosted: Wed Feb 16, 2005 11:35 am    Post subject: Reply with quote
Dobre program je uz hotovy.Zatial ho tu hodime len na test a ak pojde na vsetkych tipoch tak ho uverejnime.Dieg0
Page 2 of 2
