:: View topic - DEFINITIVNÍ ODHALENÍ: CX65 je absolutně totožná s CX70
Goto page Previous  1, 2, 3, 4
Mám pravdu?
Ano
70%
 70%  [ 22 ]
Ne
29%
 29%  [ 9 ]
Total Votes : 31
wolkow
PostPosted: Sun Feb 13, 2005 2:51 pm    Post subject: Reply with quote
kesu wrote:
zso wrote:
Tak tu je zaloha FF z mobilu CXT70
http://zso.host.sk/index.php?dir=upload/cx70/
zso
Tak jsem to nahrál. Běhá to bezproblému
A udelal jsi neco pred nahranim, nebo hned jsi to tam hodil hned?
Zpozoroval jsi nejake zmeny (hlavne ty k lepsimu Very Happy )? A pak IMEI se musi zmenit ve Freia, kdyz to chci udelat?
A co vse jeste s souvisí s nahranim FF z jineho founu? Krom toho, ~e tam budou veskere uz. nastaveni a soubory z puvodniho founu?
C35i[fw,odbloc,logo,melodie a výměna krytu Very Happy]>Alc 303>C65[spoustá patchů... Bootcore error Embarassed]>A50>M50]>M55>CX65>DCA 510>CX75
kesu
14913.56 SMM
PostPosted: Sun Feb 13, 2005 3:13 pm    Post subject: Reply with quote
wolkow wrote:
zso
http://www.siemensmania.cz/forum/viewtopic.php?p=73877#73877
wolkow
PostPosted: Sun Feb 13, 2005 3:18 pm    Post subject: Reply with quote
Dik. Nez jsem poslal ten prispevek tak uz pribyly dva mezi tim Think
Asi to taky zkusim.
krvesaj
PostPosted: Sun Feb 13, 2005 11:36 pm    Post subject: Flexmemory CX70 Reply with quote
čau, nevíte někdo kde by se dala sehnat flex paměť z CX70?? d'oh! d'oh! Think Think Poraďte, díky všem Shocked
Dieg0
19990.28 SMM
PostPosted: Sun Feb 13, 2005 11:42 pm    Post subject: Reply with quote
NEMEN NAZOV PREDMETU!!!Flex mozes tusim vytiahnut cez Smelter z FuBu.Dieg0
krvesaj
PostPosted: Mon Feb 14, 2005 12:00 am    Post subject: Reply with quote
Já myslel kde se dá stáhnout z netu?
zso
PostPosted: Mon Feb 14, 2005 10:08 am    Post subject: Re: Flexmemory CX70 Reply with quote
Question A co by si presne potreboval?
zso
C35 -> M35 -> S35 -> MT50 -> CX65 FW25 -> FW 43 -> FW 50 -> SE K750i
S65 FW 53 ->Nokia N95 8GB
kesu
14913.56 SMM
PostPosted: Mon Feb 14, 2005 1:25 pm    Post subject: Re: Flexmemory CX70 Reply with quote
a co si takle pořádně pročíst celej tenhle topic? pak by si se numusel zbytečneě ptát. (na straně 3 to 100% najdeš)
a tady jsou 1.zkušenosti http://www.siemensmania.cz/forum/viewtopic.php?p=73877#73877
karci
(člen klubu SM)<br>začátečník
PostPosted: Mon Feb 14, 2005 2:57 pm    Post subject: CX70 vraj nema Push to talk! Reply with quote
Caute hosi,
v poslednom case sa tu rozbehli temy o totoznosti medzi CX65 a CX70. Moze to byt pravda, ta CX70 co som mal v ruke mala firmware absolutne totozny s CX65 a aj sa hlasila ako CX65. Sam som do nej aplikoval patch na service menu z CX65 a zbehlo to bez problemov.
Dnes som bol v Siemensackom servise na Stromovej a typek mi potvrdil, ze oba telefony su hardwarovo absolutne totozne, vraj uplne jediny rozdiel je ta ina farba krytu. Co je ale zarazajuce, typek tvrdil ze CX70 takisto nema ziadnu extra podporu pre Push to talk. To ma dost zarazilo, ved vsetky oficialne dokumenty tvrdia ze to podporuje PTT. Ale je pravda, ze ten telefon nema ziadne tlacitko navyse (ktore akosi pre PTT predpokladam) a takisto v menu telefonu nie je nic co by o PTT signalizovalo. To, ze pri DSE existuju nejake odkazy na Push To Talk funkcie, nemusi znamenat nic ine, len to, ze to bolo planovane ale sa to nestihlo naimplementovat (PTT funkcie si vidim aj na CX65, ktora to povodne tiez mala podporovat).
Ostava otazka, ci je PTT len softwarova zalezitost alebo k tomu treba nejake extra zelezo, co CX65 nema. Ksicht v siemensackom servise tvrdil, ze v oboch pripadoch (CX65 a CX70) tam chyba nejaky hardware a ze sa to nebude dat rozbehat. To mi znie zo vsetkeho najviac pochybne.
Neviem, ci niekde uz PTT nejaky operator spustil. Mate s tym uz niekto skusenosti a co si vobec o tomto celom myslite?
BEZY
81.16 SMM
PostPosted: Mon Feb 14, 2005 3:09 pm    Post subject: Re: CX70 vraj nema Push to talk! Reply with quote
karci wrote:
Caute hosi,
v poslednom case sa tu rozbehli temy o totoznosti medzi CX65 a CX70. Moze to byt pravda, ta CX70 co som mal v ruke mala firmware absolutne totozny s CX65 a aj sa hlasila ako CX65. Sam som do nej aplikoval patch na service menu z CX65 a zbehlo to bez problemov....
Já bych spíš řek, že to Siemens ani v jednom (65/70) nepovolil, kvůli nepodpoře operátora. Jediný, kdo se PTT chystá spustit je Eurotel, ale zatim tak neučinil
http://www.bezysoftware.net
Brew Mobile Commander 2.0
zso
PostPosted: Mon Feb 14, 2005 3:13 pm    Post subject: Reply with quote
Mobil z ktorého som vytiahol ten FF po natikani *#06# vypisal cx70 a po spojeni s V_klayom tiez CX70 Patche som neskusal, lebo mobil nie je moj No a funkciu PTT som nemal sancu vyskusat, ani overit, lebo s telefonom som sa nehral, ani menu som si nepozrel. Mozno ked bude sused doma tak kuknem ci je niekde v menu PTT, alebo ci sa da nejako nastavit
zso
doplnene: manual CX70-ky pise o funkcii Walky-Talky, takze malo by to ist
kesu
14913.56 SMM
PostPosted: Mon Feb 14, 2005 3:33 pm    Post subject: Reply with quote
zso
myslím si,že ani na té orig CX70 to v menu nebude protože,kdyby to tam bylo,tak bych to měl i teď v mé CX65.
myslím si že pokud to operátor povolí tak se to tam objeví,popř se bude muset nahrát novej fw
zso
PostPosted: Mon Feb 14, 2005 3:42 pm    Post subject: Reply with quote
tak nam nezostava nic ine ako cakat, kym nietkory operator spusti PTT
zso
kesu
14913.56 SMM
PostPosted: Mon Feb 14, 2005 4:07 pm    Post subject: Reply with quote
zso
bohužel,asi to tak bude
Page 4 of 4
