hotter badatel
 Založen: 04. 12. 2004 Příspěvky: 141 Bydliště: Lithuanian Telefon: M55 47266.46 SMM
Zaslal: pá září 30, 2005 1:52 pm Předmět: What do these patch? |
;Speed of a blinking of the cursor
;Smooth illumination turn-on
I dont understand what they do  _________________ N3310 -> M55sw91 + Hotter tuning + 3.75mb -> CXV70sw50 + Hotter MacOS tuning + 11.27mb + blue diods + winamp + headphones -> SX1sw15 + Hotter tuning + 2gb -> Asus P525 + Vista tuning + 2gb -> N3310 + Hotter tuning + M55sw91 + 4.14mb + patches + PSP -> M55 + Patches + DCA-510usb |
Dieg0 siemensmaniak
19990.28 SMM
Zaslal: pá září 30, 2005 2:08 pm Předmět: |
;Speed of a blinking of the cursor : This patch is speed up blinking a cursor.Cursor is "|".Where is it?This cursor is in writing new message, writing file name and more
;Smooth illumination turn-on : This patch make slower acceleration of illumination.The illumination is fully turn on for 2-3 seconds.The default turning on of illumination is 0,1 second _________________ ...odstraneno - prilis velky obrazek... |
hotter badatel
Zaslal: ne říjen 16, 2005 11:46 am Předmět: |
I applyed this patch: * MyStuff = Disk Menu v0.1 *
But i dont understand what it do? in my stuff menu nothing changed
And whad do these patchs:
*Decimal LAC instead of N & B in neighbour list instead of ENIP monitor*
* Extended AT+CGSN command *? _________________ N3310 -> M55sw91 + Hotter tuning + 3.75mb -> CXV70sw50 + Hotter MacOS tuning + 11.27mb + blue diods + winamp + headphones -> SX1sw15 + Hotter tuning + 2gb -> Asus P525 + Vista tuning + 2gb -> N3310 + Hotter tuning + M55sw91 + 4.14mb + patches + PSP -> M55 + Patches + DCA-510usb |
lacibogi čestný člen
Zaslal: ne říjen 16, 2005 11:51 am Předmět: |
*MyStuff = Disk Menu v0.1*
If you want to see some changes you must edit xml file which configurates directories in Media Album. You can find it in config/default/Mystuff.
Codes for each discs.
kód: |
Disc A - Data-ROOT-SLASH
Disc B - Cache-CNSI-CUSTOMER4
Disc C - Config-CNSI_CUSTOMER5 |
You can edit in some hex editor.  _________________ C(ME)75
Lasky |
