:: View topic - s65 questions
s65 questions
Reply to topic     Forum Index -> Non Czech Languages Here
mobile
PostPosted: Sun Mar 12, 2006 1:39 am    Post subject: s65 questions Reply with quote
I saw at m65 download a bin file (lgp) are they langpacks?Very Happy it`s a *.bin file. does it have the romanian language? i think it works in s65 also. but how do i install it? (i can use v_klay on my phone).
what`s S65_FLEX.exe ? (i have donwloaded it from the s65 section) is it the oldest version of software? for example if i want to downgrade to sw50 should i install thins thing and than the update from siemens website?
how do i install romanian language on my phone?
what`s the difference between the variant of software? (ex.A370)... if install an update witch is for the variant a500 and i have a370 does the phone get damaged?
is the s75 sofware tunning hard? risky?
i know that they are a lot of questions... but this are my big dillemas refering to s65...
best regards,
Andrei, Romania
zoxir
PostPosted: Sun Mar 12, 2006 1:29 pm    Post subject: Reply with quote
1, It´s only czech-slovak langpack.
2, S65_FLEX.exe is something like filesystem backup.
3, If you want to downgrade to fw50 (58->50) you need to use winswup 50.
4, In different variants are diffenrent langpacks.
5, Tuning applying is not so hard. Just like patching. Smile
mobile
PostPosted: Tue Mar 14, 2006 2:16 pm    Post subject: Reply with quote
where can i find winswup 50? Embarassed
zoxir
PostPosted: Tue Mar 14, 2006 4:07 pm    Post subject: Reply with quote
Arrow http://www.siemensmania.cz/dnld.php?id=13438
andrei3288
PostPosted: Tue Mar 14, 2006 10:49 pm    Post subject: Reply with quote
thanks i have managed to install sw50 back and i installed the a500 update from the siemens website (in order to have the romanian language). i want to ask if it exists... sw58 variant a500 (or something with romanian language..) or how can i save the langpack from the phone and after updating to install it?
thx
Andrei, Romania (this is my new user ... i don`t use mobile anymore... i have managed to create my own account)
siemens m55 -> nokia 6230 -> siemens s65 v58 -> siemens sl55 -> siemens cx65 -> siemens sl75 v47
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Wed Mar 15, 2006 10:02 am    Post subject: Reply with quote
You can´t download fw58 a500 from Siemens sites because it´s not an official fw.
To save lgp from fw50 use Smelter. But it´s not 100% sure that it will work. Maybe the sentences in fw are longer. But you can try.
andrei3288
PostPosted: Sat Apr 01, 2006 1:33 pm    Post subject: Reply with quote
i didn`t work... or probablyi i didn`t know how to make it... i have another question regarding my s65.. the contrast at the camera or at the display are to high... is there a patch to fix this problem? or something like that... the pictures on the computer look fine but those on the display are orible... Neutral for the camera i only installed the 100% compresion jpeg patch... is there something else? i have sw50. does the cammera work better on sw 58? what other improvments has sw58 beside sw50? another problem is that a 3gp file is played in frames(suks). any videocip or so... and even some film made with the phone ar bad... is there something to fix this? (i have tried also a very fine player for this phone... it`s video & music). i would like to send it to you to be showed on the site and another dca 540 driver (the file on the site doesn`t work..)
is there another player for s65 beside media emvironment?
does the patch better java working slow other aplication of the phone? (like mouvies for example)
What program should i use to unlock a siemens a57 phone? (i have tried freia and it didn`t work)
hope i didn`t bother you with my multitude of questions...
best regards, Andrei
Reply to topic     Forum Index -> Non Czech Languages Here All times are GMT + 1 Hour
