:: View topic - Muzu prehrat?
Muzu prehrat?
Quentin
PostPosted: Thu Mar 16, 2006 1:39 pm    Post subject: Muzu prehrat? Reply with quote
Kdyz jsem si predelal c65 na sl65,muzu ted do mobilu nahrat bez problemu FW53cz pro sl65 bez problemu?Diky!
PostPosted: Thu Mar 16, 2006 2:51 pm    Post subject: Reply with quote
Ano,samozrejme...mas predsa uz telefon SL65 wink
Quentin
PostPosted: Thu Mar 16, 2006 3:06 pm    Post subject: Reply with quote
No sl65......neco mu predse chybi!Dik za radu hned si ten FW nahraju!
PostPosted: Thu Mar 16, 2006 3:15 pm    Post subject: Reply with quote
Ja viem,ze mu toho dost chyba...ale je tam FW z SL75.... wink
Kazdopadne si predtym urob zalohu,ak by to zblblo...ono sa tam vlastne potom este nahrava nejaky patch,takze neviem,ci som Ti aj neporadil zle... Anxious ale vyskusat mozes,ak budes mat zalohu FF,nic sa nestane.
//EDIT
Tak keby sa to nezaplo,skus tento patch:
Code:
;C65 -> SL65 SW53
1184488: 00 03
122D204: 0E 00
Quentin
PostPosted: Fri Mar 17, 2006 1:44 pm    Post subject: Reply with quote
Ja zalohuji po kazde kdyz se vrtam v eeprom!Hned jak to zkusim tak Ti dam vedet!Ale radsi to zkusim z tim patche!
