hotter badatel
 Založen: 04. 12. 2004 Příspěvky: 141 Bydliště: Lithuanian Telefon: M55 47266.46 SMM
Zaslal: ne srpen 13, 2006 1:07 pm Předmět: EL71 memory card |
What max size of Micro SD memory card i can use in BenQ-Siemens el71?
I saw 1GB Micro SD card... it will work with el71?  _________________ N3310 -> M55sw91 + Hotter tuning + 3.75mb -> CXV70sw50 + Hotter MacOS tuning + 11.27mb + blue diods + winamp + headphones -> SX1sw15 + Hotter tuning + 2gb -> Asus P525 + Vista tuning + 2gb -> N3310 + Hotter tuning + M55sw91 + 4.14mb + patches + PSP -> M55 + Patches + DCA-510usb |
SandStorm kolemjdoucí
Založen: 13. 08. 2005 Příspěvky: 21
107.42 SMM
Zaslal: ne srpen 13, 2006 4:44 pm Předmět: |
yes, 95% probably to work.  _________________ The storm of www.siemensplanet.com
Thank you for your help on my phone patching SiemensMania!!!!! |
hotter badatel
Zaslal: po srpen 14, 2006 4:59 pm Předmět: |
And maybe there is the bigger Micro SD card then 1GB which works with EL71?
P.S. I like a lot of space  _________________ N3310 -> M55sw91 + Hotter tuning + 3.75mb -> CXV70sw50 + Hotter MacOS tuning + 11.27mb + blue diods + winamp + headphones -> SX1sw15 + Hotter tuning + 2gb -> Asus P525 + Vista tuning + 2gb -> N3310 + Hotter tuning + M55sw91 + 4.14mb + patches + PSP -> M55 + Patches + DCA-510usb |
N3o21 řád zlaté antény
 Založen: 04. 07. 2004 Příspěvky: 914
5892.50 SMM
Zaslal: po srpen 14, 2006 5:18 pm Předmět: |
I think that 2GB should work.
I don't know what filesystem uses Siemens mobiles, but i suppose they're using FAT16. And this filesystem supports memory cards to 2GB of size (1 GB must works without problems).
But I'm not sure.
If you find what filesystem is EL71 using, you can get the maximum card size. |
hotter badatel
Zaslal: po srpen 14, 2006 6:18 pm Předmět: |
So maybe someone know what filesystem is EL71 using  _________________ N3310 -> M55sw91 + Hotter tuning + 3.75mb -> CXV70sw50 + Hotter MacOS tuning + 11.27mb + blue diods + winamp + headphones -> SX1sw15 + Hotter tuning + 2gb -> Asus P525 + Vista tuning + 2gb -> N3310 + Hotter tuning + M55sw91 + 4.14mb + patches + PSP -> M55 + Patches + DCA-510usb |
107.42 SMM
Zaslal: po srpen 14, 2006 8:43 pm Předmět: |
I think it is FAT16.
But do you remember the SL45i?
Only on FW56 it started to support up to 1Gb memory cards, while previously it didn't.
Is just a matter to try those 2gb cards on EL71 and discover if yes, or don't.  _________________ The storm of www.siemensplanet.com
pip@ administrátor
Zaslal: po srpen 14, 2006 10:01 pm Předmět: |
I think, so 2GB card can be use in EL71, because with S75 it run well and EL71 and S75 are similar. _________________ Siemens: C35i, M35i, SL45i (aka U35), ME45 (aka Panther), C65 (aka Hera), M65 (aka X-cite), S75 (aka Minos), SG75 (aka Wolf4), SXG75 (aka Wolf5), EF81 (aka Kestrel)
