Spectre_x kolemjdoucí
Založen: 22. 10. 2005 Příspěvky: 1
Zaslal: po září 25, 2006 8:09 pm Předmět: Menu push on Main Screen HELP! |
Hi !
I want to know how install the Menu push on Main screen patch, step by step installion of this patch !
This is because Dancas2 and I have a little problem with that improvement..We have the same result after apply the patch.. the cell turn off when it load the menu... or touch a keypad...so we want who fix this error !
Ah where I can download the library file (vklay patch) for master patch?
Thanks |
dancas2 kolemjdoucí
Založen: 21. 09. 2005 Příspěvky: 28
Zaslal: po září 25, 2006 11:11 pm Předmět: |
The library functions patch is in Patches section of Siemensmania ..
Bye |
