:: Zobrazit téma - what are these patch use for ? 19 patches ! (S65-f
Odpovědět na téma    Obsah fóra -> Non Czech Languages Here
moeinm37
Založen: 27. 11. 2005
PříspěvekZaslal: so říjen 21, 2006 7:00 am    Předmět: what are these patch use for ? 19 patches ! (S65-f Odpovědět s citátem
hi:
i want to know what are these patch use for ? complete instruction please ??!!?!?!?
1-
;* Change time of automatical keypad lock *
; (c) SiNgle
; Smelter auto-patch
;All delays are separated to intervals of ~5 ms
;example: 65000ms/5=0x32C8 => C832, 130000ms/5=0x6590 => 9065
16A0360: C832 7017
what time ? times changes to what ?
2-
;* Transparency in Native Menu *
; (c) SiNgle, Nitrogen
; (p) Centrino
121A545: FFFFFF64 A9ABA900 ;set \"0\" color to transparent
3-
;* Addition to PIT table *
; (c) 1nvisible
; (r) avkiev
; (p) KiRiK
;Now you can assign PIT addresses to pics #1242(0x4DA)-#1341(0x53D) in free memory (0xA0FD0050)
# Known Probs
# You can't yet view or edit these pics by means of SPC3 (c) ACiD[mrp]\b@iLLi or Smelter (c) avkiev
11599C4: FFF7F5FF 76F61CFB
#pragma enable old_equal_ff
0FD0000: 0A4B984207DC084B984204DBC01AC000
0FD0010: 034BC01810BD89F1CCFC024B1847C046
0FD0020: 5000FDA0C99915A1DA0400003D050000
#pragma disable old_equal_ff
09295A8: D904 3D05 ; MaxPitNumber 1241->1341 (just for reference)
what is PIT table ? and Addition to PIT table ?
4-
;* Decimal LAC instead of N & B in neighbour list instead of ENIP monitor *
; (r) SiNgle
; (p) KiRiK
;Combined with "Decimal CID instead of C1 & C2 in neighbour list"
;Switch to CID mode with keys 0 <-> 2
08DF494: 0E 0D
08DF576: 1622281C 0E26A5E7
09287A4: ABAF34 19A936
136AA72: 002908D1 0E2E08D0
136AACE: 0122211C0B31F0789FF6B2ED0122211C0D313079 203EF08B20360522002800280522211C0B310028
13EE11D: 4E2042 4C4143
;09356F8: 454E4950204D6F6E69746F72 4E65696768626F72204C4143 ; ENIP Monitor -> Neighbor LAC
5-
;* Disable Menu End Beep Sound *
; (c) ThE TrIFoN
; (p) KiRiK
08C857C: D2EB 0022
what is "Menu End Beep sound" ?
6-
;* Reboot Instead Of Timer *
; (c) ThE TrIFoN
; (p) KiRiK
# choose any appropriate shortcut
092E920: 9B9C8DA0 443C26A1
i can not understand !
7-
;* Profile Switcher on low battery v2.5 *
; (c) Kibab
; (r) avkiev, KreN
; (!) MasterPatch
; (!) GraphLoader
0FC3E38: 0xA0FC5001 ; entrypoint 3 in GraphLoader
0FC5000: FFB52448FBF7FCFD3CD0B178FBF718FB
0FC5010: 3A78FBF719FB387800280DD0F379022B
0FC5020: 30D0FAF7F5FF7071B371F378581EFAF7
0FC5030: F3FF0220F07125E0F379002B09D0012B
0FC5040: 14D0022B1ED17079FAF7E6FF0020F071
0FC5050: 18E08A4216D8FAF7DBFF30717478201C
0FC5060: 0138FAF7D9FF0120F0710BE0B178FBF7
0FC5070: E7FA3A788A4205DD3079FAF7CDFF0020
0FC5080: F071FFE7FFBD
0FC5090: 0xB1C2D3E4,0x0000C601,0000000000000000,"\
{patch=ChangeProfile ver=2.0 cp=Kibab id=C601 mem=6}\
{1 b `Profile to switch to:` range=1..6 v=6}\
{2 sl `Accu level:` range=0..100 v=30}\
{3 b `Profile when charging:` range=1..6 v=1}",00
swith to what profile ? automatic ?
8-
;* Don't Turn Off When Battery Is Low *
; (c) ThE TrIFoN
; (p) KiRiK
; Don't use it too often. It can damage your accumulator!
129A950: B824FFEB 229610EB
1263C38: 0010A0E30000A0E389C0FFEA 08402DE90030A0E30880BDE8
16C01E0: FFFFFFFFFFFFFFFFFFFFFFFF 0010A0E30000A0E3821AEFEA
what is "accumulator" ? and where to use ?
9-
;* uptime stats v2 *
; (c) benj9
; (p) -=[LCW]=-ExXtReMe
; (!) API
; (!) Library: f002, f004, f022, f079, if missing, patch shuts down phone.
; shows a short message with session duration at shutdown.
; will be also launchable directly by keysequencer by call thumb: A092993D
0C35630: 00220092 F4F46EF9
1263C38: 0010A0E30000A0E3 04F01FE5259992A0
0929910: 344A1068002801D11360FFE700220092
0929920: 70470000
0929924: 00B500F009F800210020024F3F68B847
0929934: 00BD0000E09992A0
092993C: FFB5022700F031F899280FD008ACA4B0
092994C: 00F03FF8244D2E68811B00F008F80090
092995C: 019125A110A800F012F824B0FFBD60B5
092996C: 2848042700F019F8061C274800F015F8
092997C: 051C3C2000F011F8321C2B1C60BD051C
092998C: 7646162700F00EF8C046B8470120291C
092999C: 00224F2700F001F8B74680B500F002F8
09299AC: B84780BD60B5FF000C4EBF197F687D1C
09299BC: 002D00D560BDA54600200021054FB847
09299CC: 00BD0EB584B0064A68469047181C04B0
09299DC: 0EBD00006C3E25A1080200A80000FCA0
09299EC: 987824A1E8030000757074696D652025
09299FC: 69640D253032693A253032693A253032
0929A0C: 6900000080510100100E0000
10-
;* Disable MMI Logging *
; (c) SiNgle
; (p) KiRiK
; (r) 1nvisible
08BCEB9: B5 47 ; speeds up phone operation
is good ? patch it ? speed ?
11-
;* Change Ring Time *
; (c) Along
; (p) KiRiK
0C191F0: C8AF0000 C0D40100 ; Alarmclock (2 minutes)
0A9CB40: C8AF0000 C0D40100 ; Appointment (2 minutes)
;2 minutes -> 120 secs -> 120000 Msecs -> 0001D4C0 -> C0D40100
i can not understand "Change Ring Time" ? ring time ? change to what ?
12-
;* RamMissedEventAddrSpike *
; for people with moving/unknown missed events/sms/calls/tasks ram addresses
; (c) benj9
; (r) BuG
0C6D4A0: 041C081C 70F30AFF ; S65v58
0FDE280: 4D6945765F5370696B652C62656E6A39
0FDE290: 002706E0102704E0142702E0182700E0
0FDE2A0: 1C2740B5074E3668002E01D5BF1940BD
0FDE2B0: 054F00263E6040BD041D02480460043C
0FDE2C0: 081C7047,0xA8000100,0xA8000110 ; 2 free ram dword's (both 4 byte)
/* drop these lines into function library and uncomment the old ones
6A0: 004F3847,0xA0FDE291 ; +0x00, v12: RamMissedEvents for * RamMissedEventAddrSpike *
668: 004F3847,0xA0FDE295 ; +0x10, v05: RamMissedSMS for * RamMissedEventAddrSpike *
660: 004F3847,0xA0FDE2A1 ; +0x1C, v04: RamMissedCalls for * RamMissedEventAddrSpike *
; for future purpose included:
;??: 004F3847,0xA0FDE299 ; +0x14, v??: RamMissedMMS? for * RamMissedEventAddrSpike *
;??: 004F3847,0xA0FDE29D ; +0x18, v??: RamMissedTasks for * RamMissedEventAddrSpike *
13-
;* Decrease Keypad Long Press Delay *
; (c) 1nvisible
; (r) benj9
; (p) KiRiK
115851E: 82 41
"Long Press Delay " ? ???
14-
* Wallpaper Cycle 0.9 *
; cycles through pictures of a folder
; (c) benj9
; (!) MP, func lib: f: 4,20,22,66,77,88,99,100,107-109,160. v: 11,18,19
169C4F2: 2421614312688A182132 C046,004FB847,0xA0FD932F ; S65v58
0FD9300: 57704379636C6530392C62656E6A3900
0FD9310: 944C2468002C00D170470120A0704DE0
0FD9320: F0B50020E6F7FCFFE6F7F6FFF0BD55B5
0FD9330: 67291FD1E7F7D0F9388800281AD0894E
0FD9340: 3468002C0CD18648E6F7AAFE041C11D0
0FD9350: 34608349E6F7B4FF012000F013F809E0
0FD9360: 00F0E4F806D02169002903D02960D5BC
0FD9370: 0020B0BDD5BC04372421614312685218
0FD9380: 213238476EB5061C0DD0012E07D0B168
0FD9390: 3C204143F079091800F0CFF806E01921
0FD93A0: 00F0CBF802E0062100F0C7F803A20132
0FD93B0: 201C0830E6F758FF6EBD0000F0B5E7F7
0FD93C0: 87F93878012830D00026664C2468002C
0FD93D0: 2BD000F0ABF823D000F02AF8A1780129
0FD93E0: 15D0B179002912D0E278002804D0002A
0FD93F0: 0BD00022E27015E0002A06D100F032F8
0FD9400: 0ED0E6F789FF0122E27000200BE00028
0FD9410: 00D108E000F026F802D0FFF781FF01E0
0FD9420: 00262661301CFFF7ADFF0022A270F0BD
0FD9430: FEB5E7F731F93878002811D0E6F7E8FE
0FD9440: 01280DD0E7F748F900203F5EA278012A
0FD9450: 02D0002F04D401E0013701D0012000E0
0FD9460: 0020FEBD7EB598B0002E54D0321C1C32
0FD9470: 331C0C33684638A1E6F71AFE6946221C
0FD9480: D432101DE6F768FF002809D00125211C
0FD9490: D431081DE6F764FF002801D00135F6E7
0FD94A0: 211CD431081DE6F75FFF002D33D000F0
0FD94B0: 35F8061C01256946221CD432101DE6F7
0FD94C0: 4BFF002813D0002E0AD0211CD431081D
0FD94D0: E6F746FF00280AD0B54201DA0135F4E7
0FD94E0: 211CD8310D1C28350E1CA93600E00025
0FD94F0: 211CD431081DE6F737FF002D0BD02A1C
0FD9500: 331C201C1030011D016011A1E6F7F8FF
0FD9510: 201C103000E0002018B07EBD00B52088
0FD9520: 0130A84200DB0020208000BD3EB5CC20
0FD9530: 0002C930E7F764FB3EBD80B505200002
0FD9540: 143041430620E6F76BFD011C80BD0000
0FD9550: 25735C25730000002573257300000000
0FD9560: 10030000,0xA8000218 ; free ram 4 bytes
0FD9580: E4D3C2B1C9CC00000000000000000000,"\
{patch=WallpaperCycle ver=0.9 cp=benj9 id=CCC9}","\
{28 sd `\nFolder` ml=95 contains=`*.*` v=`0:\\Pictures\\`}","\
{12 s `\nMask` ml=15 v=`*.jpg`}","\
{6 o `\nChange Mode (change only in no-patch profile)` `MS/active`=0 `not MS/passive`=1}","\
Cycle Time (min. 8 sec){8 i Minutes v=0}{7 b Seconds v=20}",00
; 0FD93A6: 06 03 ; default cycle time sec. if WP change is waiting for opportunity, patch recycles by this time
; 0FD939E: 0i25 0i45 ; seconds patch starts after boot net animation (dont set less 20 sec)
/* Usage:
+ Minutes, Seconds
-Active Mode: Interval after that patch changes WP at mainscreen
-Passive Mode: After given time patch changes WP in Screensaver (or Menu,List)
+ Folder, Mask
Choose images folder and appropriate mask (if mask like *.* finds files/folders that are no images, no wp is displayed)
+ Change Mode
-'Active' mode changes WP only at mainscreen, but doesn't work well with animations.
-'Passive' mode changes WP only in menus or screensaver. Needs screensaver to change. After the cycle time is run out and phone enters screensaver or menu, wp is changed. This works with animated Gif.
-> if wallpaper doesnt work correctly after changing Mode during patch already runs, reboot.
+ External Calls (by external launcher, e.g. key sequencer)
- Load Next Wallpaper: call A0FD9311, immediatly loads next file
- Reload Wallpaper: call A0FD9321, reloads current wallpaper. After entering patch off profile,this reloads originally set wp.
+ Patch Config:
After Cycle Time is finished, patch tries to change WP (at mainscreen in active mode, not at mainscreen in passive mode). If phone is at that moment in "wrong" state, patch waits in short cycles and retries. Set short retry interval below. Short time means, patch reacts fast. Long time (10 seconds) means, patch reacts slow, but doesnt affects performance.
+ Known problems (this is 0.9):
- 'Active mode' doesnt like animations too much. If not displayed, refresh by
calling by key 'Reload Wallpaper'.
- 'Reload key' seldomly causes WP display to stop, then reboot
same as screen saver ? in what mode this patch happen and execute ?
15-
;* Smart Illumination *
; (c) B0Ba
; (p) -=(Kad)=-
; The phone turns keypadlight off from morning till evening
; Just set time of moring begins and when begins evening
0D08A54: 9C0D24A1 0xA0FC3B31
0FC3B10: 506F727465642066726F6D2073373576
0FC3B20: 3332206279202D3D284B6164293D2D20
0FC3B30: F0B50FB40D48FDF763F801D10FBC11E0
0FC3B40: 82B000206946FCF75BFA6D462C7802B0
0FC3B50: 0FBC012806D17578AC4203D3B578AC42
0FC3B60: 00D20022FCF76CFAF0BD0000,0x00B0BA02
0FC3B70: 0xB1C2D3E4,0x00B0BA02,0000000000000000
0FC3B80: "\
{p=`Smart Illumination` id=B0Ba02 cp=BoBa ver=1}\
{info `The phone turns keypadlight off from morning till evening`}\
{1 sl Morning r=0..23 v=8}\
{2 sl Evening r=0..23 v=18}",00
like NOKIA ? conflict with what ? with "Screen Illumination Auto Control v2.1" ?
with "Setup illumination by 5%" ? with " Illumination fade time" ? with " Smooth illumination turn-on" ?
with "Change Illumination Turn Off Timer 2" ? with "Change Illumination Turn Off Timer v3" ?
16-
;* MegaLoudness *
;(c) SiNgle
;(p) KiRiK
12592A4: 2600C4E5 D3FFFFEA
12591FC: 030000EF 030040E2
1259200: 6C2DA0E30100A0E3 2600C4E5290000EA
17-
;* Disable Some Debug *
;(c) benj9
0B57CB0: 10B5 7047
0B57D24: 0FB4 7047
18-
;* Disable More Nasty Debug *
;(c) benj9
0A3E1AC: FFB5 7047
19-
;* Wallpaper Cycle v0.91 *
;S65v58
;(c) benj9
;(r) 1nvisible, LazyCODEr
;(p) -=(Kad)=
;(i) Masterpatch
169C4F2: 2421614312688A182132 C046004FB8472F93FDA0
0FD9300: 57704379636C6539312C62656E6A3900
0FD9310: 9E4C2468002C00D170470120A0704FE0
0FD9330: 672921D1E7F7D0F9388800281CD0934E
0FD9340: 3468002C0CD19048E6F7AAFE041C13D0
0FD9350: 34608D49E6F7B4FF012000F015F80BE0
0FD9360: 00F0F7F808D0874800190168002903D0
0FD9370: 2960D5BC0020B0BDD5BC043724216143
0FD9380: 12685218213238476EB5061C0DD0012E
0FD9390: 07D0B1683C204143F079091800F0E0F8
0FD93A0: 06E0192100F0DCF802E0052100F0D8F8
0FD93B0: 03A20132201C0830E6F756FF6EBD0000
0FD93C0: F0B5E7F785F93878012837D0E7F77CF9
0FD93D0: 3888002832D100266C4C2468002C2DD0
0FD93E0: 00F0B7F823D000F02CF8A178012915D0
0FD93F0: B179002912D0E278002804D0002A0BD0
0FD9400: 0022E27017E0002A06D100F034F80ED0
0FD9410: E6F782FF0122E27000200DE0002800D1
0FD9420: 0AE000F028F802D0FFF77AFF03E00026
0FD9430: 544800190660301CFFF7A6FF0022A270
0FD9440: F0BDFEB5E7F728F93878002811D0E6F7
0FD9450: DFFE01280DD0E7F73FF900203F5EA278
0FD9460: 012A02D0002F04D401E0013701D00120
0FD9470: 00E00020FEBD7EB598B0002E54D0321C
0FD9480: 1C32331C0C3368463CA1E6F711FE6946
0FD9490: 221C1032101DE6F75FFF002809D00125
0FD94A0: 211C1031081DE6F75BFF002801D00135
0FD94B0: F6E7211C1031081DE6F756FF002D33D0
0FD94C0: 00F035F8061C01256946221C1032101D
0FD94D0: E6F742FF002813D0002E0AD0211C1031
0FD94E0: 081DE6F73DFF00280AD0B54201DA0135
0FD94F0: F4E7211C14310D1C28350E1CA93600E0
0FD9500: 0025211C1031081DE6F72EFF002D0BD0
0FD9510: 2A1C331C1B480019011D016015A1E6F7
0FD9520: EFFF1848001900E0002018B07EBD00B5
0FD9530: 7079002806D0E7F7D3F8381C291CE6F7
0FD9540: 57FF04E020880130A84200DB00202080
0FD9550: 00BD3EB5CC200002C930E7F751FB3EBD
0FD9560: 80B505200002143041430620E6F758FD
0FD9570: 011C80BD25735C257300000025732573
0FD9580: 000000005402000010030000,0xA8000218 ; free ram 4 bytes
0FD9590: E4D3C2B1C9CC00000000000000000000,"\
{patch=WallpaperCycle ver=0.91 cp=benj9 id=CCC9}","\
{28 sd `\nFolder` ml=95 contains=`*.*` v=`0:\\Pictures\\Wallpaper\\`}","\
{12 s `\nMask` ml=15 v=`*.*`}","\
{6 o `\nChange Wallpaper at (only change in off-profile)` `Mainscreen`=0 `ReturnToMS`=1}","\
{5 cb `Random Order`}","\
Cycle Time (min. 8 sec){8 i Minutes v=5}{7 b Seconds v=0}",00
0FD93AA: 05 03 ; default cycle time sec. if WP change is waiting for opportunity, patch recycles by this time
0FD93A2: 0i25 0i12 ; seconds patch starts after boot net animation (dont set less 12 sec)
what version do we have install ? which of them newer ?
thanks a lot and excuse me !
Vladimir Curcic
Založen: 30. 04. 2005
PříspěvekZaslal: so říjen 21, 2006 2:50 pm    Předmět: Odpovědět s citátem
Oh man, there are so many things that you don't understand!
My friendly advice is that you should better forget patching your phone, for now.
Once, when you learn some necessary stuff, you might consider this idea again...
Shocked
S65(FW58) | IFL-600 (External flash) | DCA500
MY CURRENT COLLECTION: ME45 | S45i | CX65-LtdEd | S65 | SL75
Odpovědět na téma    Obsah fóra -> Non Czech Languages Here Časy uváděny v GMT + 1 hodina
