herry_potter kolemjdoucí
 Založen: 13. 01. 2006 Příspěvky: 27 Bydliště: West Java, Indonesia
63.58 SMM
Zaslal: po listopad 27, 2006 4:01 am Předmět: SXG75 : How to improve MP3 sound quality on RS-MMC? |
I get problem when playing MP3 I have stored on RS-MMC.
The MP3 songs always "jump" (sound was not smoothly playing).
I have tried with 3 kind of RS-MMC : 32MB Sandisk, 256MB V-Gen and 1GB Kingston.
I use 23in1 Card Reader to format it in FAT.
Is here anyone have the same experience? How to improve the sound quality?
Regards,
Herry Potter |
hungeri začátečník
Založen: 21. 02. 2005 Příspěvky: 43
Zaslal: út listopad 28, 2006 12:22 pm Předmět: Re: SXG75 : How to improve MP3 sound quality on RS-MMC? |
herry_potter napsal: | I get problem when playing MP3 I have stored on RS-MMC.
Regards,
Herry Potter |
Hi there!
I use takeMS dual voltage RS-MMC (1GB) in my M75, and I haven't experienced this kind of problem yet. The sound becames unsmooth if editing the playlist while playing it, but only, if I browse too fast among the songs... So, my suggestion is to format the card with the phone and first try copy files only via the phone if possible. If after this everything is the same, I have no more idea... |
Bonfire čestný člen
Příspěvky na SM: 110,- |
Zaslal: út listopad 28, 2006 3:54 pm Předmět: |
try to choose song with lower bitrate, or you can backup data from MMC, format it in PC, and copy files back to MMC, it is better than defragmentation _________________ C1,C2,C3,C4,C5,P1,S3,S3plus,S3com,S4,S6,S8,C10,E10,S10,S10active,SL10,U10,S15,C25,C28,S25,C30,M30,A35,A36,C35,M35,S35,S40,S42,
hungeri začátečník
Zaslal: út listopad 28, 2006 6:44 pm Předmět: |
My M75 plays the songs with a bitrate 320kbps. I think on the SXG is an other problem, and I suggest him to format the card ON THE PHONE again... It will allocate the right file system and dictionaries, 100% surely... |
63.58 SMM
Zaslal: st listopad 29, 2006 1:41 am Předmět: |
hungeri napsal: | My M75 plays the songs with a bitrate 320kbps. I think on the SXG is an other problem, and I suggest him to format the card ON THE PHONE again... It will allocate the right file system and dictionaries, 100% surely... |
Hi hungeri & bonfire, thanks for your suggestion. I have done it. I use 32MB Sandisk, 256MB V-Gen and 1GB Kingston on my M75. All are OK.
But when I use them on SXG75, all become un-smooth.
It is impossible to FORMAT the card by the SXG75 itself!
No option on Settings\Phone\Filesystem....only Memory Assistant.
What I can do is formatting using PC and I have done it via card reader 23 in 1.
Nothing changed! _________________ E71 SL91 E81 M81 M7 SXG75 S75 M75 M65 CXT65 M55 ME45 SL45i SL45 SL42 SX1 S25 S10D S6
DCA-500, DCA-510, DCA-540, DCA-100, DCA-140 DIP-100 |
Bonfire čestný člen
Zaslal: st listopad 29, 2006 6:42 am Předmět: |
then maybe mp3s can be in very high bitrate...
i have CX75, SX1 and SXG75, i haven't got any problem with playing mp3s on SXG75, only when MP3 is in bitrate greater than 256kbps, then when i am listening MP3s and playing some games in one time, MP3 plays unsmooth, with interrupts, but when i play MP3 with smaller bitrate, it's OK...
or try to re-encode MP3s on PC with other compressor or settings (i am using newest LAME encoder, 128kbps VBR, and sound is small and good quality) _________________ C1,C2,C3,C4,C5,P1,S3,S3plus,S3com,S4,S6,S8,C10,E10,S10,S10active,SL10,U10,S15,C25,C28,S25,C30,M30,A35,A36,C35,M35,S35,S40,S42,
FOXXX VIP
Zaslal: st listopad 29, 2006 12:42 pm Předmět: |
přeložte mu někdo ještě, že některá témata ku*ví MP3 taky... např winXP _________________ S10, C35, C40, 2x S35, S45, ME45, M55, S55, S65, S75, CF110, SL45i, SXG-75, HTC Artemis, HTC Touch Cruise
HKW600,HTC Touch HD
BEZY čestný člen
81.16 SMM
Zaslal: st listopad 29, 2006 1:43 pm Předmět: |
Some of the themes may affect the songs. I guess this problem occures when the mp3 name (or ID3tag) is too long - either make it shorter or jump out of the media player (using task handler button). Or you may change your theme _________________ C35i -> M35i -> M50 -> CX65 -> SX1McLaren -> SXG75 -> HTC HD
http://www.bezysoftware.net
Brew Mobile Commander 2.0 |
hungeri začátečník
Zaslal: st listopad 29, 2006 1:47 pm Předmět: |
herry_potter napsal: | hungeri napsal: | My M75 plays the songs with a bitrate 320kbps. I think on the SXG is an other problem, and I suggest him to format the card ON THE PHONE again... It will allocate the right file system and dictionaries, 100% surely... |
Nothing changed! |
If M75 plays smoothly, then your sxg75 must be bad! I can't imagine othe way... |
63.58 SMM
Zaslal: pá prosinec 01, 2006 1:46 am Předmět: |
BEZY napsal: | Some of the themes may affect the songs. I guess this problem occures when the mp3 name (or ID3tag) is too long - either make it shorter or jump out of the media player (using task handler button). Or you may change your theme |
Perfect BEZY! Your analyse is correct. The sound becomes unsmooth because of themes selection.
When I use "AUDI" theme (see below), then sound quality becomes WORST.
But...when I choose "Eintracht" theme, sound quality is very GOOD.
Now I can enjoy MP3 smoothly.
Thanks to all of you guys, for your support.
Regards,
Herry Potter _________________ E71 SL91 E81 M81 M7 SXG75 S75 M75 M65 CXT65 M55 ME45 SL45i SL45 SL42 SX1 S25 S10D S6
