aslankadir1989 kolemjdoucí
Založen: 21. 07. 2005 Příspěvky: 4
Zaslal: st únor 07, 2007 11:19 am Předmět: help |
you are the best in the world about siemens so help me pls
i want send elf my phone
how can i do
or
i active it with which programme
or
can you explain all thing and program
(türkish or english)
thanks |
Orpheus čestný člen
14900.34 SMM
Zaslal: st únor 07, 2007 4:12 pm Předmět: |
You need to find the right patch for your phone, and aplicate patch Elfpack 1.8+ and i think you need also patch "Funkce a variabilní knihovny".
Then you can open elf files in your phone. Put them to 0:/Zbin/ and launch them thru phone, or to 0:/Zbin/Daemons if you want it to start automatically at phone start.
In 0:/Zbin/etc create a file extension.cfg where you can put configurations if needed.
For seeing the folder Zbin in phone, aplicate patch "Zobrazení všech disků a skrytých zložek v telefonu", go to phone explorer and press 1 and Show All. |
