[email protected] kolemjdoucí
Založen: 26. 12. 2006 Příspěvky: 17
80.82 SMM
Zaslal: st červen 17, 2009 9:49 pm Předmět: Remove MagicLinks.xml without cable |
Hi
How to remove Config\Default\MagicLinks.xml from my sk65 ? I don't have data cable or IRDA. I've tried to use java app called Zeus but it cant delete this file.(I have no idea why) |
kylo rozumbrada
 Založen: 01. 01. 2008 Příspěvky: 309 Telefon: S65 30.30 SMM
80.82 SMM
Zaslal: čt červen 18, 2009 1:05 pm Předmět: |
ThX for info i've modified old x55 cable to x 65
(from www.siemensiak.pl) |
simp moderátor
Zaslal: čt červen 18, 2009 1:21 pm Předmět: |
You can´t change data on disc Config. It´s locked. You can unlock it with data cable or IRDA. With bluetooth it is not possible. _________________ M50 unlock java † → CX70 FW56 Elfpack 2.3 † → S65 FW58 Elfpack 2.3 |
