:: View topic - Kto to umi z Freiu???
Willi
Guest
PostPosted: Sun Dec 19, 2004 7:49 pm    Post subject: Kto to umi z Freiu??? Reply with quote
Prosim poradte ked som si chcel zmenit IMEI tak ma freia odbyla tymto:
TTY_OpenCOMPort : opening COM3
COMM_IsBootRunning : bootcode does not seem to be running
COMM_LoadBoots : Waiting to power on the phone ...
COMM_LoadBoots : phone is powered on
COMM_LoadBoots : internal loader version is 01.00
SEC_BCDIMEIToNormalIMEI : invalid decoded IMEI
COMM_LoadBoots : EEPROM IMEI (17) is corrupt
COMM_LoadBoots : original IMEI is 35194400079607 (locked)
COMM_LoadBoots : found SIEMENS C60 lg4 v14 (1)
COMM_LoadBoots : flash ids are 00012212 [00000000] - 1201
COMM_LoadBoots : phone ids are 6C2F0E77 [6C2F0E77]
COMM_UpdateIMEIBlocks : update is not accepted
co mam s tym urobit aby to slapalo??? Dakujem
Bonfire
Phone: HTC HD2
9259.32 SMM
PostPosted: Sun Dec 19, 2004 9:00 pm    Post subject: Reply with quote
mas spatny IMEI v EEPROM, prehraj EEPROM ve V_KLayi
Koupím Siemens, který nemám.
Willi
Guest
PostPosted: Mon Dec 20, 2004 3:37 pm    Post subject: Ako na to? Reply with quote
To ako mam ten fullflash C60 lg4 v14 dat do fonu cez V_klay a potom prepisat imei cez Freiu???
PostPosted: Mon Dec 20, 2004 3:43 pm    Post subject: Re: Ako na to? Reply with quote
Nejjednodušším řešením je mít zálohu EEPROM z V-Klay z původního firmware. Potom nahrát nový fullflash a přehrát původní EEPROM opět pomocí V-Klay.
Willi
Guest
PostPosted: Mon Dec 20, 2004 7:43 pm    Post subject: Uf problem... Reply with quote
Notak som sa pustil do toho ale...
Nahraval som tam fullflash a zrazu to akosi dlho stalo na adrese 0x003C0000 hmm asi 10 minut tak som ho reset.
Potom mi to urobilo opat na inej adrese. Ked sa takto dopracujem az do konca dam vediet potom hadam uz tu freiu presvedcim ze uz som si svoje vytrpel a chcem opat moju c60-tku.
Tak zatial dakujem
Lukash
PostPosted: Mon Dec 27, 2004 10:30 am    Post subject: Reply with quote
Melo by ti stacit prehrat EEPROM a pak zmenit IMEI telefonu... v pripade ze by ti to neslo napis mi na ICQ Dancing
Siemens MC60
fw13cz | 3.50MB | grafické a systémové patche | USB
Siemens CF62
fw13cz | 1.57MB | žádné patche (nemužu patchnout bootcore)
www: http://www.lukys.ic.cz
ICQ: 304-717-273
willi
Guest
PostPosted: Wed Dec 29, 2004 11:33 am    Post subject: Tak a teraz ako pre debila ako pre mna.... Reply with quote
Nahral som si Fullflash cez V_klay. Trvalo mi to cca. 28 min a nahralo sa to bez chyby. Teraz by som si mal asi pustit freiu a dat direct unlock...
Vyskusal som vsetky moznosti a stale nic.
A etste jedno zistenie. Chcel som ist na to od "lesa" tak som si nacital pamat s kamošoveho fonu (taktiež c60) a chcel som to dal do mojho. Potom ma tak napadlo že sa pozrem čo tam mam. No a na moje počudovanie tam je velke h.... dokonca aj smelter vyhodi chybu.
Tak co je suci ten "Siemens" do odpadu????
Vdaka za dalsie rady...
