:: View topic - bezpečnostní kod u M65?
tjklatovycz
PostPosted: Mon Apr 04, 2005 12:31 pm    Post subject: bezpečnostní kod u M65? Reply with quote
Zdravim lidičky. Může mi nekdo poradit, jak odblokovat bezpečnostní kod u Siemense M65? Mam i GSMkey, ale nic to zatim nezvladlo?
Prosim o radu? Applause Question Question
PostPosted: Mon Apr 04, 2005 12:36 pm    Post subject: Reply with quote
Program SST 5.31 a Unlock.
Orpheus
14900.34 SMM
PostPosted: Mon Apr 04, 2005 12:55 pm    Post subject: Reply with quote
jj, SST + unlock.
MLB
PostPosted: Mon Apr 04, 2005 5:17 pm    Post subject: Reply with quote
SST sa mi vobec nechce spojit. Iny sposob (Sie EEPROM tool sa tiez nespoji)? Pray
CX70 fw56
PostPosted: Mon Apr 04, 2005 6:12 pm    Post subject: Reply with quote
Nespojí se ani Siemens EEPROM tool? Tak to máš blbý. Jiná cesta není, jde o úpravu bloků EEPROM.
ficik
PostPosted: Mon Apr 04, 2005 6:41 pm    Post subject: Reply with quote
netusim sice vo cem presne se bavite Shocked Shocked ale nemusi mit ten patch 323 Odkrytí všech bloků EEPROM nekamenovat prosim jenom napad.
CX65@70
<:.Ficik.:>
View user's profile Send private message Send e-mail Visit poster's website AIM Address Yahoo Messenger MSN Messenger
PostPosted: Tue Apr 05, 2005 9:58 am    Post subject: Reply with quote
A mas vobec servisny kabel..s EEPROM Tool sa spoji takmer vzdy,aj ked je uplne mrtvy.
MLB
PostPosted: Tue Apr 05, 2005 3:40 pm    Post subject: Reply with quote
No, lenze mne sa nespoji a to pritom mobil beha OK. Mozno je to tym, ze mobil kabel nedetekuje (je totiz z x55), ale nahral som nim firmware, robil screeny, nahraval patche aj cital z Papuy.....
Vazne to inac nejde? Ze by sa tie bloky EEPROM dali do telefonu inym sposobom (V-Klay, x65Flasher,... ?) - tie bloky idu v tom EEPROM tool ulozit aj vo formate bin alebo eep, ale co s tymi ulozenymi subormi Question
CX70 fw56
MLB
PostPosted: Tue Apr 05, 2005 3:45 pm    Post subject: Reply with quote
Oprava, spoji sa (jasne cervene tlacitko Embarassed ), telefon nabehne do Service mode, program vypise Getting Info a koniec - po chvili vypise Stopped d'oh!
CX70 fw56
PostPosted: Tue Apr 05, 2005 7:14 pm    Post subject: Reply with quote
Ano i mě to dělá, nejlepší finta je dát INIT v EEprom tool při zapnutém mobilu a ten okamžitě naskočí. Přišel jsem na to omylem a funguje vždy napoprvé. Po nahrání co je potřeba a stisku EXIT se telefon vypne.
MLB
PostPosted: Fri Apr 08, 2005 6:21 pm    Post subject: Reply with quote
Diky Krokodyle, fakt diky! Predtym som tvoju odpoved prehliadol, ale teraz som to skusil a ide to. A to som to tam nahral cez DCA540 (vlastne je to logicke, ked telefon zapisuje EEPROM pocas behu, tak by to malo ist aj s DCA540)....
btw. nahraval som cez DCA540, pretoze neupravovany servis. kabel z x55 nekomunikoval...
CX70 fw56
