:: View topic - TEMATA
TEMATA
Goto page 1, 2  Next
KADLA
PostPosted: Mon Jun 06, 2005 11:57 pm    Post subject: TEMATA Reply with quote
AHOJ LIDI
STAHNUL JSEM SI NEJAKE TEMATA ZE SM.VSECHNY JSOU ZAZIPOVANE.NO A KDYZ JE OTEVRU TAK JE TAM SPOUSTA SOUBORU,NO A JA NEVIM KTERY Z NICH MAM PREKOPIROVAT DO PHONU.MYSLEL JSEM SI ZE JE TO SOUBOR S PRIPONOU *.STC ALE KDYZ TO STAHNU A PAK TO CHCI V TELEFONU OTEVRIT,TAK TO PISE SE CHYBI JEDEN NEBO VICE ZDROJU.CO S TIM,JAK NA TO?
DIKY VSEM Rolling Eyes
S65 FW25 (RS-MMC 256MB)
diablo
PostPosted: Tue Jun 07, 2005 12:07 am    Post subject: Reply with quote
Niesom v tomto odbornik, ale Arrow http://www.siemensmania.cz/forum/viewtopic.php?t=11494&highlight=themes
Staci dat hladat slovo themes a riesenie mas na dosah.
M35 upravena -> MT50 tuned-> MC60 -> M55 fw10 ->fw11 ->fw91 (+patche) ->dead -> SX1 fw13 ->fw15 uk-de-ru ->fw15 uk-cz-sk + themes +1GB Pretec
For Blood is Life...
And1111
PostPosted: Tue Jun 07, 2005 5:09 am    Post subject: Reply with quote
Skopiruj do telefonu ten zazipovany a ked to nepojde tak v telefone len odstran priponu .zip tak ze premenujes subor.
PostPosted: Tue Jun 07, 2005 6:20 am    Post subject: Reply with quote
Ziadna z tem na SM nie je zazipovana,je vo formate SDT,ktory je beznym standartnym formatom pre temy na x65.Staci skopirovat do Data/Themes a aktivovat...zbytok uz urobi sam telefon.
KADLA
PostPosted: Tue Jun 07, 2005 8:35 am    Post subject: Reply with quote
DIKY,JA TO JDU TEDA ZKUSIT 8)
Guest
PostPosted: Tue Jun 07, 2005 9:46 am    Post subject: Reply with quote
TAK JSEM TO ZKUSIL.PREPSAL JSEM PRIPONU *.ZIP NA *.STC NO A KDYZ JSEM TO CHTEL AKTIVOVAT,TAK TO NAPSALO "KONFIGURACE PRERUSENA AKTIVACE SE NEZDARILA" Rolling Eyes
jay.hp
PostPosted: Tue Jun 07, 2005 9:55 am    Post subject: Reply with quote
Přejmenuj tona *.sdt!!!!!!!!!!!!!
A odkial mas tu temu?Daj link.
PostPosted: Tue Jun 07, 2005 10:11 am    Post subject: Reply with quote
Vidis,to som prehliadol,ze to premenoval STC a nie SDT.... d'oh!
vbvbvb
PostPosted: Tue Jun 07, 2005 10:29 am    Post subject: Reply with quote
to nevadi ked napise ze chyba jeden alebo viac zdrojov. Ja si z kazdej temy vymazem zvuky a animacie a vzdy napise tu chybu. Da sa to tam prepisat ale nic sa nestane ked to napise.
PostPosted: Tue Jun 07, 2005 10:44 am    Post subject: Reply with quote
To je v poriadku,ale on dal priponu celej temy SDT namiesto STC a chcel ju aktivovat.
vbvbvb
PostPosted: Tue Jun 07, 2005 10:49 am    Post subject: Reply with quote
ved tema ma priponu sdt nie stc nie: Think
KADLA
PostPosted: Tue Jun 07, 2005 11:14 am    Post subject: Reply with quote
DIKY UZ TO FUNGUJE S PRIPONOU *.sdt
TA PRVNI PRIPONA CO JSEM PSAL *.stc JSEM JI MEL V MOBILU U OSTATNICH TEMAT,TAK JSEM SI MYSLEL ZE TY OSTATNI TO MAJI MIT TAKY. JINAK LINK NA TO TEMA JE TADY http://www.siemensmania.cz/themes.php?view_all=true&phone_type=1&type=2
JE TO LARA CROFT
DIKY Applause
PostPosted: Tue Jun 07, 2005 11:56 am    Post subject: Reply with quote
Ta Lara nie je v ZIPe,ale ako ostatne temy, v STD...tak nechapem,co si sachoval s tymi priponami,ked stacilo ponechat tu povodnu... Rolling Eyes
KADLA
PostPosted: Tue Jun 07, 2005 1:04 pm    Post subject: Reply with quote
TAK TO TEDA NEVIM Rolling Eyes KDYZ JSEM SI TO STAHNUL DO POCITACE,TAK MI TO PSALO ZE JE TO ZIP FILE A DOKONCE KDYZ JSEM TO CHTEL V KOMPLU OTEVRIT TAK MI TO NABIDLO WINZIP Rolling Eyes
Goto page 1, 2  Next
Page 1 of 2
